sketch_jan17a:31:14: error: 'RCA' was not declared in this scope
Something very strange is happening. The following code works but only if I use switch variables listed on the YouTube example: Using IR Remote Controls with the Arduino - YouTube at around 11:00 minutes into the podcast.
But when I change a case variable not on the list the podcast list, I get the error:
error: ‘RCA’ was not declared in this scope
What is going on please. Thank you in advance.
I pasted the code for convenience:
#include <IRremote.h>
#include <IRremoteInt.h>
//#include <stdio.h>
//Define sensor pin
const int RECV_PIN = 4;
//Define IR Receiver and Results Objects
IRrecv irrecv(RECV_PIN);
decode_results results;
// Serial Monitor @ 9600 baud rate
//Enable the IR Receiver
irrecv.enableIRIn();
if(irrecv.decode(&results)){
//Print code in HEX
Serial.println(results.value, HEX);
switch (results.decode_type){
case NEC:
Serial.println(“NEC”);
case MITSUBISHI:
Serial.println(“MITSUBISHI”);
case DISH:
Serial.println(“DISH”);
case SONY:
Serial.println(“SONY”);
default:
Serial.println(“UNKNOWN”);
irrecv.resume();
Please post the full error message
From IRremote.h I don’t see an RCA.
// An enumerated list of all supported formats
// You do NOT need to remove entries from this list when disabling protocols!
typedef
	enum {
		UNKNOWN      = -1,
		UNUSED       =  0,
		RC5,
		RC6,
		NEC,
		SONY,
		PANASONIC,
		JVC,
		SAMSUNG,
		WHYNTER,
		AIWA_RC_T501,
		LG,
		SANYO,
		MITSUBISHI,
		DISH,
		SHARP,
		DENON,
		PRONTO,
		LEGO_PF,
decode_type_t;
