Sketchbook directory in linux
Hello. I'm running Arduino 0015, in Kubuntu 8.04.
It runs and works correctly, except for one annoying detail: when I go to open a new sketch, the file dialog defaults to the directory the arduino program is in, not my sketchbook directory.
When I save, or 'save as', a current sketch, it starts out in my sketchbook directory
preferences.txt points the sketchbook to /home/username/sketchbook, which I have set up correctly.
any ideas?
Hi Yen1,
this is hardcoded in ArduinoIDE sources, there is nothing you can do about it, sorry.
Eberhard
In File/Preferences you tell the IDE your sketchbook location.
It works perfectly on my PC running Ubuntu, with the sketchbook in my home directory
Hi, I have no problems either with 9.04 (32bits) / 0015...
I think we were talking about the
File->Sketchbook->Open
menu, and this starts up in the Arduino-application directory by default.
This is different from
File->Save
or
File->Save as...
which correctly starts up in the Sketchbook-dir that was set in the preferences.
Eberhard
Hmm. In that case, I'm thinking of digging through the code and recompiling my IDE. :slight_smile:
Should I start out by just suggesting the change (in a the software/suggestions thread), or by writing a patch, or what?
the fix is easy:
In file Sketchbook.java
you simply have to uncomment line No. 322
change
//fd.setDirectory(getSketchbookPath());
to
and the OpenDialog starts in the Sketchbook folder.
I'll see this gets on the todo list for the next release.
Thanks for pointing this out. I never really realized this strange behaviour but I think you are totally right that this should be fixed.
Eberhard
