Sketchbook location: no international characters?
(I'm using Arduino 009 on an Intel Mac)
I changed my Sketchbook location in Preferences, but whenever I restart the Arduino program I get this message:
Sketchbook folder disappeared The sketchbook folder no longer exists, so a new sketchbook will be created in the default location.
This is an error with the software, which doesn't allow the Sketchbook to reside in a folder with an international character in its name. If I rename one of the folders (that is, remove the international character) Arduino accepts the location.
Try for yourself, use this character: ó in a folder name.
Is there an easy fix to this?
I just tried it myself, no luck. Quick workaround though:
Open Arduino’s preference file
~/library/arduino/preferences.txt
Look for the entry…
sketchbook.path=
…and change it to your path e.g.
sketchbook.path=/path/to/fólder/
Arduino seems to input a ‘?’ when you do it by GUI. If you change it manually it works :slight_smile:
Ah! Thanks so much for your help! :)
