Hello guys, I'm very new to Arduino programming. Anyway what I'm trying to do is connect the RFID reader to my Arduino UNO which I have done but the ZIP folders you get online don't work, Ive been trying to upload the sketch from Dumpinfo to my Arduino UNO but it comes up with this error, can anyone please help me and tell me if theres something wrong with the sketch maybe. Ive copied in the sketch from the Dumpinfo folder after the errors.
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SoftwareSerial is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
/var/folders/vz/1rs3zpvj79n7j__l0y3ln18r0000gn/T/arduino_modified_sketch_19489/sketch_feb08c.ino:21:18: fatal error: RFID.h: No such file or directory
#include <RFID.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Uno.
The Sketch:
- Read a card using a mfrc522 reader on your SPI interface
- Pin layout should be as follows (on Arduino Uno):
- MOSI: Pin 11 / ICSP-4
- MISO: Pin 12 / ICSP-1
- SCK: Pin 13 / ISCP-3
- SS: Pin 10
- RST: Pin 9
- Script is based on the script of Miguel Balboa.
- New cardnumber is printed when card has changed. Only a dot is printed
- if card is the same.
- @version 0.1
- @author Henri de Jong
@since 06-01-2013
#include <SPI.h>
#include <RFID.h>
#define SS_PIN 10
#define RST_PIN 9
RFID rfid(SS_PIN, RST_PIN);
// Setup variables:
int serNum0;
int serNum1;
int serNum2;
int serNum3;
int serNum4;
SPI.begin();
rfid.init();
if (rfid.isCard()) {
if (rfid.readCardSerial()) {
if (rfid.serNum[0] != serNum0
&& rfid.serNum[1] != serNum1
&& rfid.serNum[2] != serNum2
&& rfid.serNum[3] != serNum3
&& rfid.serNum[4] != serNum4
/* With a new cardnumber, show it. */
Serial.println(" ");
Serial.println("Card found");
serNum0 = rfid.serNum[0];
serNum1 = rfid.serNum[1];
serNum2 = rfid.serNum[2];
serNum3 = rfid.serNum[3];
serNum4 = rfid.serNum[4];
//Serial.println(" ");
Serial.println("Cardnumber:");
Serial.print("Dec: ");
Serial.print(rfid.serNum[0],DEC);
Serial.print(", ");
Serial.print(rfid.serNum[1],DEC);
Serial.print(", ");
Serial.print(rfid.serNum[2],DEC);
Serial.print(", ");
Serial.print(rfid.serNum[3],DEC);
Serial.print(", ");
Serial.print(rfid.serNum[4],DEC);
Serial.print("Hex: ");
Serial.print(rfid.serNum[0],HEX);
Serial.print(", ");
Serial.print(rfid.serNum[1],HEX);
Serial.print(", ");
Serial.print(rfid.serNum[2],HEX);
Serial.print(", ");
Serial.print(rfid.serNum[3],HEX);
Serial.print(", ");
Serial.print(rfid.serNum[4],HEX);
/* If we have the same ID, just write a dot. */
Serial.print(".");
rfid.halt();
