Sketches not uploading to new Arduino Uno (Windows 10)
I'm having trouble with a brand new Arduino Uno in Windows 10. I'm trying to test it with the first project in SparkFun's Inventor's Kit, "Blinking an LED." However, I'm getting communication errors whether the simple circuit is connected or not.
I'm using version 1.8.13 of the IDE.
Things I've tried:
  • ran the loopback test and that works
  • restarted, reinstalled, etc, multiple times
  • all of the USB ports on my laptop
  • I'm currently working in Windows 10, but I got the same errors in Ubuntu 20.04.
Here's the output when I try to upload the sketch:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\tcarroll\AppData\Local\Temp\arduino_build_809936/SIK_Circuit_1A-Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\tcarroll\AppData\Local\Temp\arduino_build_809936/SIK_Circuit_1A-Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | ################################################## | 100% 0.16s
avrdude: 924 bytes of flash written
avrdude: verifying flash memory against C:\Users\tcarroll\AppData\Local\Temp\arduino_build_809936/SIK_Circuit_1A-Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\tcarroll\AppData\Local\Temp\arduino_build_809936/SIK_Circuit_1A-Blink.ino.hex:
avrdude: input file C:\Users\tcarroll\AppData\Local\Temp\arduino_build_809936/SIK_Circuit_1A-Blink.ino.hex contains 924 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: stk500_recv(): programmer is not responding
######avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
option enabled in File -> Preferences.
Thanks for the help!!
Cheers,
tom
Can you compile and upload the BareMinumum sketch with nothing connected to the Uno ?
Where did you download the IDE from ?
@UKHeliBob Thanks for the reply.
I get the same error when I try to upload the bare minimum sketch.
I downloaded the IDE from https://www.arduino.cc/en/Main/Software. (On Ubuntu I also tried installing from the repository.)
Cheers,
tom
I ran across this while searching.
Mikeybear:
Maybe a little late now , but I managed to get arid of this error , by using an USB 2 port instead of a USB 3 port
Regards
@kprims Thanks for the suggestion ... but all of the ports on my laptop are USB 3. (Nonetheless, I've tried them all!)
The normal way to get around USB 3.0 issues is to insert a powered USB 2.0 hub.
It is a known and accepted fix for most USB 3.0 issues.
It simply acts as a downgrade to USB 2.0
Thanks for the suggestions everyone. I purchased a USB 2.0 hub (this one) but I'm still getting the same errors.
I suspect a bad board at this point, but I will have the chance to try it on a different machine this week.
Cheers,
tom
