Hey guys, i just got an arduino uno and decided to upload a blink sketch to it in order to test it out. I am running the 2017 MacBook pro, and plugged in the arduino with a USB-C adapter. When i clicked upload, i got the following error:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "COM1": No such file or directory
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
I tried selecting the different ports on my computer, but they are all USB-C, and i used a USB-C adapter.
Select the appropriate port from the Tools -> Port menu.
The fact that it's trying to use COM1 (the "default" port, which only exists on windows systems) indicates that you have never selected a port. If the ports menu is greyed out, you have driver problems or are using a bad cable (there's been a plague of defective USB cables recently)
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x32
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x32
Hey, you should try check your Serial Port in DEVICE MANAGER.
I was facing the same problem but once i opened device manager, it became available to select Port from the Arduino software.
Hello,
I am having this error while uploading my sketch, Please help me out
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd7
Hello
I am working with uno3 and ubuntu, when i whant to upload my program i have this warning :
Arduino: 1.8.5 (Linux), Board: "Arduino/Genuino Uno" Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes. avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions. This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences
can anyone help me?
Thanks.
Elnazt:
Hello
can anyone help me?
Thanks.
Don't hijack threads with unrelated problems.
Your issue is that you have the wrong port selected, and/or your user is not a member of the dialout group, and hence does not have access to the serial ports (by default, users do not have permissions to access serial ports)
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd2
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd2
Sketch uses 962 bytes (2%) of program storage space. Maximum is 32256 bytes.
Looks like you have to add yourself to the dialout group.
I'm having issues in connecting my Arduino mega 2560 on windows 10. it connected once, when I uploaded a check program on it, now that program is running but it is not recognized by os. port option is grey and unusable. Tx, Rx led's are on while I'm not using them. I supplied 12 volts power and it's IC just burnt my finger instantly so I unplugged it and using USB to operate right now. please help me to solve my issue. Thanks
Usama_Ameen:
