Hello!
I have a strange problem.
I made Aduino Single-Sided Serial Board (version 3), which is connected to my PC COM1
When you do upload Sketches, "Blink," for example, avrdude properly establish communication (Mount D13, and Blink RX
and TX) says that everything is fine but does not start sketch (not blinking) ...... I tried to replace and port
(diode + 220 Ohm resistor) but no change ...
Burned bootloader is: ATmegaBOOT.hex (from Arduino 1.0.5 release)
For burning bootloader I use PonyPrg parallel programmer.
Fuses burned is:
BootLock12
BootLock11
CKOPT
BOOTSZ1
BOOTRST
SUT1
Actually you can see programing with PonyPrg on YouTube: Menanam Bootloader untuk Arduino Severino (ATmega8) - YouTube
The chip is: atmega8-16pu
This is start and end AvrDude message:
Binary sketch size: 890 bytes (of a 7,168 byte maximum)
C:\Program Files\Arduino\hardware/tools/avr/bin/avrdude -CC:\Program Files\Arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega8 -carduino -P\.\COM5 -b19200 -D -Uflash:w:C:\Users\Marija\AppData\Local\Temp\build7347850926885553381.tmp\Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files\Arduino\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM5
Using Programmer : arduino
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
AVR Part : ATMEGA8
Chip Erase delay : 10000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 20 128 0 no 512 4 0 9000 9000 0xff 0xff
flash 33 10 64 0 yes 8192 64 128 4500 4500 0xff 0x00
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
avrdude: verifying ...
avrdude: 890 bytes of flash verified
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
Any Idea??
