Last login: Fri Apr 12 09:03:05 on console
Ross@iMac ~ % "/Applications/Arduino IDE.app/Contents/MacOS/Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/electron-main.js, destination 'package.json': /Applications/Arduino IDE.app/Contents/Resources/app/package.json
2024-04-12 18:14:15.648 Arduino IDE[32962:629543] WARNING: Secure coding is not enabled for restorable state! Enable secure coding by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState: and returning YES.
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T09:53:59.281Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T09:53:59.281Z"}
Starting backend process. PID: 32984
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///Users/Ross/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-04-12T22:14:15.907Z root INFO Backend Object.initialize: 1.7 ms [Finished 0.216 s after backend start]
2024-04-12T22:14:15.909Z root INFO Backend Object.configure: 1.3 ms [Finished 0.216 s after backend start]
2024-04-12T22:14:15.909Z root INFO Backend s.onStart: 0.6 ms [Finished 0.216 s after backend start]
2024-04-12T22:14:15.909Z root INFO Backend s.configure: 0.1 ms [Finished 0.228 s after backend start]
2024-04-12T22:14:15.909Z root INFO Backend d.onStart: 0.1 ms [Finished 0.228 s after backend start]
2024-04-12T22:14:15.910Z root INFO Backend d.configure: 0.0 ms [Finished 0.228 s after backend start]
2024-04-12T22:14:15.910Z root INFO Backend d.initialize: 11.3 ms [Finished 0.228 s after backend start]
2024-04-12T22:14:15.910Z root INFO Backend c.onStart: 0.1 ms [Finished 0.228 s after backend start]
2024-04-12T22:14:15.910Z root INFO Backend a.configure: 1.8 ms [Finished 0.230 s after backend start]
2024-04-12T22:14:15.911Z config INFO >>> Initializing CLI configuration...
2024-04-12T22:14:15.911Z root INFO Backend c.initialize: 0.2 ms [Finished 0.230 s after backend start]
2024-04-12T22:14:15.911Z root INFO Backend R.onStart: 0.3 ms [Finished 0.230 s after backend start]
2024-04-12T22:14:15.911Z config INFO Loading CLI configuration from /Users/Ross/.arduinoIDE/arduino-cli.yaml...
2024-04-12T22:14:15.911Z daemon INFO Starting daemon from /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/resources/arduino-cli...
2024-04-12T22:14:15.911Z root INFO Backend a.initialize: 0.2 ms [Finished 0.230 s after backend start]
2024-04-12T22:14:15.911Z root INFO Backend w.onStart: 0.4 ms [Finished 0.231 s after backend start]
2024-04-12T22:14:15.911Z root INFO Backend r.configure: 0.6 ms [Finished 0.231 s after backend start]
2024-04-12T22:14:15.911Z discovery-log INFO start
2024-04-12T22:14:15.911Z discovery-log INFO start new deferred
2024-04-12T22:14:15.911Z root INFO Backend d.initialize: 0.2 ms [Finished 0.231 s after backend start]
2024-04-12T22:14:15.911Z root INFO Backend y.onStart: 0.7 ms [Finished 0.231 s after backend start]
2024-04-12T22:14:15.911Z root INFO Backend a.onStart: 0.2 ms [Finished 0.232 s after backend start]
2024-04-12T22:14:15.911Z root INFO Backend h.configure: 0.1 ms [Finished 0.232 s after backend start]
2024-04-12T22:14:15.911Z root INFO Backend s.configure: 0.0 ms [Finished 0.232 s after backend start]
2024-04-12T22:14:15.911Z root INFO Backend l.configure: 0.0 ms [Finished 0.232 s after backend start]
2024-04-12T22:14:15.912Z root INFO Theia app listening on http://127.0.0.1:50280.
2024-04-12T22:14:15.912Z root INFO Finished starting backend application: 1.0 ms [Finished 0.233 s after backend start]
2024-04-12T22:14:15.913Z root WARN The local plugin referenced by local-dir:/Users/Ross/.arduinoIDE/plugins does not exist.
2024-04-12T22:14:15.913Z root WARN The local plugin referenced by local-dir:/Users/Ross/.arduinoIDE/extensions does not exist.
2024-04-12T22:14:15.921Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://files.pololu.com/arduino/package_pololu_index.json"]},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"/Users/Ross/Library/Arduino15/libraries"},"data":"/Users/Ross/Library/Arduino15","downloads":"/Users/Ross/Library/Arduino15/staging","user":"/Users/Ross/Dropbox/Arduino Projects"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-04-12T22:14:15.921Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-04-12T22:14:15.921Z config INFO Loaded the CLI configuration.
2024-04-12T22:14:15.925Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///Users/Ross/Library/Arduino15","sketchDirUri":"file:///Users/Ross/Dropbox/Arduino%20Projects","additionalUrls":["https://files.pololu.com/arduino/package_pololu_index.json"],"network":"none","locale":"en"}
2024-04-12T22:14:15.925Z config INFO Validating the CLI configuration...
2024-04-12T22:14:15.925Z config INFO The CLI config is valid.
2024-04-12T22:14:15.925Z config INFO <<< Initialized the CLI configuration.
2024-04-12T22:14:15.932Z root INFO Resolve plugins list: 20.9 ms [Finished 0.252 s after backend start]
2024-04-12T22:14:15.991Z daemon INFO time="2024-04-12T18:14:15-04:00" level=info msg="Using config file: /Users/Ross/.arduinoIDE/arduino-cli.yaml"
time="2024-04-12T18:14:15-04:00" level=info msg="arduino-cli version 0.35.3"
time="2024-04-12T18:14:15-04:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:50281
{"IP":"127.0.0.1","Port":"50281"}
2024-04-12T22:14:15.991Z daemon INFO Daemon is running.
2024-04-12T22:14:16.043Z daemon INFO time="2024-04-12T18:14:16-04:00" level=info msg="Checking signature" index=/Users/Ross/Library/Arduino15/package_index.json signatureFile=/Users/Ross/Library/Arduino15/package_index.json.sig trusted=true
time="2024-04-12T18:14:16-04:00" level=info msg="Missing signature file" index=/Users/Ross/Library/Arduino15/package_pololu_index.json
time="2024-04-12T18:14:16-04:00" level=info msg="Loading hardware from: /Users/Ross/Library/Arduino15/packages"
time="2024-04-12T18:14:16-04:00" level=info msg="Loading package arduino from: /Users/Ross/Library/Arduino15/packages/arduino/hardware"
time="2024-04-12T18:14:16-04:00" level=info msg="Missing signature file" index=/Users/Ross/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/installed.json
time="2024-04-12T18:14:16-04:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-04-12T18:14:16-04:00" level=info msg="Checking existence of 'tools' path: /Users/Ross/Library/Arduino15/packages/arduino/tools"
time="2024-04-12T18:14:16-04:00" level=info msg="Loading tools from dir: /Users/Ross/Library/Arduino15/packages/arduino/tools"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-04-12T18:14:16-04:00" level=info msg="Loading package builtin from: /Users/Ross/Library/Arduino15/packages/builtin"
time="2024-04-12T18:14:16-04:00" level=info msg="Checking existence of 'tools' path: /Users/Ross/Library/Arduino15/packages/builtin/tools"
time="2024-04-12T18:14:16-04:00" level=info msg="Loading tools from dir: /Users/Ross/Library/Arduino15/packages/builtin/tools"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.6"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.8"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.2"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.3"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.3.5"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.10.0"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.11.0"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.12.0"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.9.1"
time="2024-04-12T18:14:16-04:00" level=info msg="Loading package pololu-a-star from: /Users/Ross/Library/Arduino15/packages/pololu-a-star/hardware"
time="2024-04-12T18:14:16-04:00" level=info msg="Missing signature file" index=/Users/Ross/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/installed.json
time="2024-04-12T18:14:16-04:00" level=info msg="Loaded platform" platform="pololu-a-star:avr@5.1.0"
time="2024-04-12T18:14:16-04:00" level=info msg="Adding libraries dir" dir=/Users/Ross/Library/Arduino15/packages/arduino/hardware/avr/1.8.6/libraries location=platform
time="2024-04-12T18:14:16-04:00" level=info msg="Adding libraries dir" dir=/Users/Ross/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/libraries location=platform
time="2024-04-12T18:14:16-04:00" level=info msg="Loading libraries index file" index=/Users/Ross/Library/Arduino15/library_index.json
Restoring workspace roots: /Users/Ross/Dropbox/Arduino Projects/4-TMP E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v1,/Users/Ross/Dropbox/Arduino Projects/4-TMP E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v2
isTempSketch: false. Input was /Users/Ross/Dropbox/Arduino Projects/4-TMP E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v1/RunningLts_StrobeLts_Nav_Dish_v1.ino
2024-04-12T22:14:16.156Z daemon INFO time="2024-04-12T18:14:16-04:00" level=info msg="Adding libraries dir" dir=/Users/Ross/Library/Arduino15/libraries location=ide
time="2024-04-12T18:14:16-04:00" level=info msg="Adding libraries dir" dir="/Users/Ross/Dropbox/Arduino Projects/libraries" location=user
isTempSketch: false. Input was /Users/Ross/Dropbox/Arduino Projects/4-TMP E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v2/RunningLts_StrobeLts_Nav_Dish_v2.ino
2024-04-12T22:14:16.215Z discovery-log INFO start resolved watching
2024-04-12T22:14:16.217Z daemon INFO time="2024-04-12T18:14:16-04:00" level=info msg="starting discovery builtin:mdns-discovery process"
2024-04-12T22:14:16.222Z daemon INFO time="2024-04-12T18:14:16-04:00" level=info msg="starting discovery builtin:serial-discovery process"
time="2024-04-12T18:14:16-04:00" level=info msg="started discovery builtin:serial-discovery process"
time="2024-04-12T18:14:16-04:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:serial-discovery"
2024-04-12T22:14:16.228Z daemon INFO time="2024-04-12T18:14:16-04:00" level=info msg="started discovery builtin:mdns-discovery process"
time="2024-04-12T18:14:16-04:00" level=info msg="sending command HELLO 1 \"arduino-cli 0.35.3\" to discovery builtin:mdns-discovery"
2024-04-12T22:14:16.277Z daemon INFO time="2024-04-12T18:14:16-04:00" level=info msg="from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-04-12T18:14:16-04:00" level=info msg="sending command START_SYNC to discovery builtin:mdns-discovery"
time="2024-04-12T18:14:16-04:00" level=info msg="from discovery builtin:mdns-discovery received message type: start_sync, message: OK"
2024-04-12T22:14:16.291Z daemon INFO time="2024-04-12T18:14:16-04:00" level=info msg="from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1"
time="2024-04-12T18:14:16-04:00" level=info msg="sending command START_SYNC to discovery builtin:serial-discovery"
time="2024-04-12T18:14:16-04:00" level=info msg="from discovery builtin:serial-discovery received message type: start_sync, message: OK"
time="2024-04-12T18:14:16-04:00" level=info msg="from discovery builtin:serial-discovery received message type: add, port: /dev/cu.Bluetooth-Incoming-Port"
2024-04-12T22:14:16.291Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"/dev/cu.Bluetooth-Incoming-Port","label":"/dev/cu.Bluetooth-Incoming-Port","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2024-04-12T22:14:16.342Z root INFO Deploy plugins list: 20.9 ms [Finished 0.663 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-04-12T22:14:16.907Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-04-12T22:14:16.909Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-04-12T22:14:16.913Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: </Users/Ross/Dropbox/Arduino Projects/4-TMP E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v2/RunningLts_StrobeLts_Nav_Dish_v2.ino>, response: </Users/Ross/Dropbox/Arduino Projects/4-TMP E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v2>.
2024-04-12T22:14:16.914Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: </Users/Ross/Dropbox/Arduino Projects/4-TMP E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v1/RunningLts_StrobeLts_Nav_Dish_v1.ino>, response: </Users/Ross/Dropbox/Arduino Projects/4-TMP E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v1>.
2024-04-12T22:14:16.982Z root INFO Start frontend contributions: 207.8 ms [Finished 0.808 s after frontend start]
2024-04-12T22:14:16.982Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-04-12T22:14:16.985Z root INFO Start frontend contributions: 204.7 ms [Finished 0.828 s after frontend start]
2024-04-12T22:14:16.985Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-04-12T22:14:16.993Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-04-12T22:14:16.994Z root INFO >>> Restoring the layout state...
2024-04-12T22:14:16.994Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-04-12T22:14:16.995Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///Users/Ross/Dropbox/Arduino%20Projects/4-TMP%20E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v2/RunningLts_StrobeLts_Nav_Dish_v2.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":1,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":451,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":285},"rightPanel":{"type":"sidepanel","items":[]}}
2024-04-12T22:14:16.995Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-04-12T22:14:17.007Z root INFO [b64f2038-3ab8-4d68-b5f9-1f9352146e74] Waiting for backend deployment: 35.1 ms [Finished 0.841 s after frontend start]
[32962:0412/181417.070520:ERROR:trust_store_mac.cc(846)] Error parsing certificate:
ERROR: Failed parsing extensions
2024-04-12T22:14:17.127Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-04-12T22:14:17.127Z root INFO >>> Restoring the layout state...
2024-04-12T22:14:17.127Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-04-12T22:14:17.127Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///Users/Ross/Dropbox/Arduino%20Projects/4-TMP%20E/Prototypes/RunningLts_StrobeLts_Nav_Dish_v1/RunningLts_StrobeLts_Nav_Dish_v1.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":1,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":332,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":285},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"arduino-sketchbook-widget"}
2024-04-12T22:14:17.127Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-04-12T22:14:17.130Z root INFO [343fead8-8953-4d88-b618-b33deedf6694] Waiting for backend deployment: 65.2 ms [Finished 0.892 s after frontend start]
2024-04-12T22:14:17.199Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992) starting instance
2024-04-12T22:14:17.199Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991) starting instance
2024-04-12T22:14:17.697Z root INFO [b64f2038-3ab8-4d68-b5f9-1f9352146e74] Sync of 23 plugins: 691.9 ms [Finished 1.533 s after frontend start]
2024-04-12T22:14:17.710Z root INFO [343fead8-8953-4d88-b618-b33deedf6694] Sync of 23 plugins: 677.2 ms [Finished 1.569 s after frontend start]
2024-04-12 18:14:17.757 Arduino IDE Helper (Renderer)[32987:629724] CoreText note: Client requested name ".NewYork-Regular", it will get TimesNewRomanPSMT rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2024-04-12 18:14:17.757 Arduino IDE Helper (Renderer)[32987:629724] CoreText note: Set a breakpoint on CTFontLogSystemFontNameRequest to debug.
2024-04-12 18:14:17.762 Arduino IDE Helper (Renderer)[32986:629722] CoreText note: Client requested name ".NewYork-Regular", it will get TimesNewRomanPSMT rather than the intended font. All system UI font access should be through proper APIs such as CTFontCreateUIFontForLanguage() or +[NSFont systemFontOfSize:].
2024-04-12 18:14:17.762 Arduino IDE Helper (Renderer)[32986:629722] CoreText note: Set a breakpoint on CTFontLogSystemFontNameRequest to debug.
2024-04-12T22:14:17.858Z root INFO <<< The layout has been successfully restored.
2024-04-12T22:14:17.859Z root INFO <<< The layout has been successfully restored.
2024-04-12T22:14:17.897Z root INFO Initialize the workbench layout: 858.1 ms [Finished 1.717 s after frontend start]
2024-04-12T22:14:17.897Z root INFO Initialize the workbench layout: 874.6 ms [Finished 1.695 s after frontend start]
2024-04-12T22:14:17.898Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-04-12T22:14:17.898Z root INFO [343fead8-8953-4d88-b618-b33deedf6694] Loading plugin contributions
2024-04-12T22:14:17.898Z root INFO [b64f2038-3ab8-4d68-b5f9-1f9352146e74] Loading plugin contributions
2024-04-12T22:14:17.899Z root INFO [b64f2038-3ab8-4d68-b5f9-1f9352146e74] Load contributions of 23 plugins: 35.6 ms [Finished 1.731 s after frontend start]
2024-04-12T22:14:17.899Z root INFO [343fead8-8953-4d88-b618-b33deedf6694] Load contributions of 23 plugins: 37.2 ms [Finished 1.755 s after frontend start]
2024-04-12T22:14:17.903Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-04-12T22:14:17.903Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-04-12T22:14:17.911Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-04-12T22:14:17.911Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-04-12T22:14:17.979Z root ERROR [hosted-plugin: 32992] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
2024-04-12T22:14:17.979Z root ERROR [hosted-plugin: 32992] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-04-12T22:14:18.046Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): PluginManagerExtImpl/init()
2024-04-12T22:14:18.047Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-arduino-api@0.1.2 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.078Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(cortex-debug@1.5.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.078Z root INFO [hosted-plugin: 32992] Debugger contribution has been registered: cortex-debug
2024-04-12T22:14:18.079Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-arduino-tools@0.1.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.079Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(cpp@1.52.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.079Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(json@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.080Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(json-language-features@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.081Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-bg@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.081Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-cs@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.082Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-de@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.082Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-es@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.083Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-fr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.083Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-hu@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.083Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-it@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.083Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-ja@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.084Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-ko@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.084Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.085Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-pl@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
PLUGIN_HOST(32992): initializing(vscode-language-pack-pt-BR@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.085Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-ru@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.085Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-tr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.085Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-uk@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.088Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-zh-hans@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.088Z root ERROR [hosted-plugin: 32991] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2024-04-12T22:14:18.088Z root ERROR [hosted-plugin: 32991] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2024-04-12T22:14:18.088Z root ERROR [hosted-plugin: 32991] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2024-04-12T22:14:18.088Z root ERROR [hosted-plugin: 32991] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2024-04-12T22:14:18.088Z root ERROR [hosted-plugin: 32991] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
2024-04-12T22:14:18.088Z root ERROR [hosted-plugin: 32991] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
2024-04-12T22:14:18.088Z root ERROR [hosted-plugin: 32991] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
2024-04-12T22:14:18.088Z root ERROR [hosted-plugin: 32991] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
2024-04-12T22:14:18.089Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): initializing(vscode-language-pack-zh-hant@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.092Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): PluginManagerExtImpl/init()
2024-04-12T22:14:18.092Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2024-04-12T22:14:18.094Z root INFO [hosted-plugin: 32992] calling activation function on Arduino IDE API for VS Code extensions
2024-04-12T22:14:18.094Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-arduino-api@0.1.2 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.095Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
2024-04-12T22:14:18.107Z root INFO [hosted-plugin: 32992] calling activation function on JSON Language Features (built-in)
2024-04-12T22:14:18.111Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/extension.js)
2024-04-12T22:14:18.119Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(cortex-debug@1.5.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.119Z root INFO [hosted-plugin: 32991] Debugger contribution has been registered: cortex-debug
2024-04-12T22:14:18.120Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-arduino-tools@0.1.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.120Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(cpp@1.52.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.121Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(json@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.121Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(json-language-features@1.46.1 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.122Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-bg@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.123Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-cs@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.124Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-de@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.124Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-es@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.125Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-fr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.125Z root INFO [hosted-plugin: 32992] calling activation function on VS Code Arduino Tools
2024-04-12T22:14:18.125Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-hu@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.125Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-it@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.126Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-ja@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.126Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-ko@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.126Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-nl@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.126Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-pl@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.127Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-pt-BR@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.127Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-ru@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.127Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-tr@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.127Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-uk@1.48.3 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.128Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-zh-hans@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.128Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): initializing(vscode-language-pack-zh-hant@1.80.0 with /Applications/Arduino IDE.app/Contents/Resources/app/lib/backend/plugin-vscode-init)
2024-04-12T22:14:18.129Z root INFO [b64f2038-3ab8-4d68-b5f9-1f9352146e74] Starting plugins.
2024-04-12T22:14:18.130Z root INFO [hosted-plugin: 32992] PLUGIN_HOST(32992): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js)
2024-04-12T22:14:18.131Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2024-04-12T22:14:18.133Z root INFO [hosted-plugin: 32991] calling activation function on Arduino IDE API for VS Code extensions
2024-04-12T22:14:18.134Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
2024-04-12T22:14:18.143Z root INFO [hosted-plugin: 32992] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-04-12T22:14:18.143Z root INFO [hosted-plugin: 32992] calling activation function on Cortex-Debug
2024-04-12T22:14:18.144Z root INFO [hosted-plugin: 32992] GDB server console created
2024-04-12T22:14:18.145Z root INFO [hosted-plugin: 32991] calling activation function on JSON Language Features (built-in)
2024-04-12T22:14:18.147Z root INFO [b64f2038-3ab8-4d68-b5f9-1f9352146e74] Start of 23 plugins: 247.3 ms [Finished 1.982 s after frontend start]
2024-04-12T22:14:18.148Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/vscode-arduino-tools/extension/dist/extension.js)
2024-04-12T22:14:18.164Z root INFO [hosted-plugin: 32991] calling activation function on VS Code Arduino Tools
2024-04-12T22:14:18.167Z root INFO [343fead8-8953-4d88-b618-b33deedf6694] Starting plugins.
2024-04-12T22:14:18.172Z root INFO [hosted-plugin: 32991] PLUGIN_HOST(32991): PluginManagerExtImpl/loadPlugin(/Applications/Arduino IDE.app/Contents/Resources/app/plugins/cortex-debug/extension/dist/extension.js)
2024-04-12T22:14:18.184Z root INFO [hosted-plugin: 32991] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-04-12T22:14:18.184Z root INFO [hosted-plugin: 32991] calling activation function on Cortex-Debug
2024-04-12T22:14:18.188Z root INFO [hosted-plugin: 32991] GDB server console created
2024-04-12T22:14:18.191Z root INFO [343fead8-8953-4d88-b618-b33deedf6694] Start of 23 plugins: 290.6 ms [Finished 2.050 s after frontend start]
Checking for update
2024-04-12T22:14:18.791Z root INFO Replace loading indicator with ready workbench UI (animation): 822.4 ms [Finished 2.580 s after frontend start]
2024-04-12T22:14:18.791Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-04-12T22:14:18.791Z root WARN Linked preference "workbench.colorCustomizations" not found.
2024-04-12T22:14:18.791Z root INFO Frontend application start: 1908.1 ms [Finished 3.100 s after backend start]
2024-04-12T22:14:18.793Z root INFO Replace loading indicator with ready workbench UI (animation): 818.4 ms [Finished 2.552 s after frontend start]
2024-04-12T22:14:18.793Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-04-12T22:14:18.793Z root WARN Linked preference "workbench.colorCustomizations" not found.
2024-04-12T22:14:18.793Z root INFO Frontend application start: 1918.1 ms [Finished 3.112 s after backend start]
2024-04-12T22:14:18.861Z sketches-service WARN Mismatching sketch file <double_blink.ino> and sketch folder name <Double_Blink>. Skipping
2024-04-12T22:14:18.916Z sketches-service WARN Mismatching sketch file <double_blink.ino> and sketch folder name <Double_Blink>. Skipping
2024-04-12T22:14:19.012Z root ERROR ---- !!!SLOW!!! DURATION: search took 218.856 ms. Args: [{"type":"Updatable"}] ----
2024-04-12T22:14:19.014Z root WARN A command arduino-include-library---:- is already registered.
2024-04-12T22:14:19.015Z root WARN A command arduino-include-library---:- is already registered.
2024-04-12T22:14:19.016Z root WARN A command arduino-include-library---:- is already registered.
Update for version 2.3.2 is not available (latest version: 2.3.2, downgrade is allowed).
