Sketches will not run on Arduino Uno
I was posting on the wrong site & getting limited/unsatisfactory responses.
I am using an Arduino uno. I have set the board to Arduino Genuino Uno com port 3, with no pin connections to anything. Prior to this I have used the board on considerably more complex programs & it worked perfectly, now it won't work on any sketches, even this simplest of all. Here is the code directly from the menu & error code:
// the setup function runs once when you press reset or power the board void setup() { // initialize digital pin LED_BUILTIN as an output. pinMode(LED_BUILTIN, OUTPUT); }
// the loop function runs over and over again forever void loop() { digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes. avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x30 avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x20 avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x30 avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x20 avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x30 avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x20 avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x30 avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x20 avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x30 avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20 An error occurred while uploading the sketch
This report would have more information with "Show verbose output during compilation"
option enabled in File -> Preferences.
I ran the loop back test, and it worked perfectly. Any suggestions?
This means the problem is not with your sketch. The IDE does not communicate with the board. First things to try: - restart PC - try another USB port - try another USB cable - try another Arduino if available
Which ever port the Arduino shows up in Device Manager is the USB port to use in the IDE.
I had to switch to Com 10 & it worked. From now on I will use the troubleshooting list then the loop back test before bothering people on this list.
Thanks for your help, guys!
