I am trying to affect the frequency of an LED with a potentiometer and then serial print the frequency in Hertz.
However, the results seemed to be skewed greatly. In the following code the printed frequency range from 5 to 100, but the number changes only from 5 to around 9.5 for the first half of turning the potentiometer, and then near the other end of the potentiometer the number changes by thirty fro a minuscule turn of the potentiometer.
Can anyone give me a solution to make the potentiometer have a constant effect (the number changes at a consistent per turn of the potentiometer) on the printed frequency?
here is my code
int dial=A0;
int readval;
float vol;
int LEDpin=13;
float freq;
pinMode(LEDpin, 13);
readval=analogRead(dial);
vol=(5./1023.)*readval;
freq=19*vol + 5;
Serial.println(1000 * (1 / (2 * freq)));
digitalWrite(LEDpin, HIGH);
delay(freq);
digitalWrite(LEDpin, LOW);
delay(freq);
It can be useful to use an exponential function when using a pot like this. Let’s say when the analog read is 0, you’d like the frequencey to be once every 2 seconds, and when it is 1023, you’d like the frequency to be 50hz. In other words, the time between blinks should vary smoothly between 2000ms and 20ms.
#include <math.h>
const float interval_at_zero = 1000 / .5; // .5Hz
const float interval_at_1023 = 1000 / 50; // 50Hz
float ln_zero;
float ln_perincrement;
// precalculate these values at startup
// note that log() is a natural log.
ln_zero = log(interval_at_zero);
// this will be negative, which is fine
ln_perincrement = log(interval_at_1023/interval_at_zero)/1023;
// target timing interval, in ms
float getInterval() {
int pot = analogRead(A0);
return exp(ln_zero + pot*ln_perincrement);
