#define pin1 2 // motor #1 +
#define pin2 3 // motor #1 –
#define pw1 6 // motor #1 pwm
#define pin3 4 // motor #2 +
#define pin4 9 // motor #2 –
#define pw2 5 // motor #2 pwm
#define pin5 7 // motor #3 +
#define pin6 8 // motor #3 –
#define pw3 10 // motor #3 pwm
#define pin7 12 // motor #4 +
#define pin8 13 // motor #4 –
#define pw4 11 // motor #4 pwm
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
pinMode(pw1, OUTPUT);
pinMode(pw2, OUTPUT);
pinMode(pin5, OUTPUT);
pinMode(pin6, OUTPUT);
pinMode(pin7, OUTPUT);
pinMode(pin8, OUTPUT);
pinMode(pw3, OUTPUT);
pinMode(pw4, OUTPUT);
digitalWrite(pin1, LOW);
digitalWrite(pin2, LOW);
digitalWrite(pin3, LOW);
digitalWrite(pin4, LOW);
digitalWrite(pin5, LOW);
digitalWrite(pin6, LOW);
digitalWrite(pin7, LOW);
digitalWrite(pin8, LOW);
analogWrite(pw1, 50);
analogWrite(pw2, 50);
analogWrite(pw3, 50);
analogWrite(pw4, 50);
if (Serial.available() >= 2 )
unsigned int a = Serial.read();
unsigned int b = Serial.read();
unsigned int val = (b * 256) + a;
if (val == 50) // motor 1 reverse
digitalWrite(pin2, HIGH);
digitalWrite(pin6, HIGH);
else if (val == 100) // motor #1 stop
else if (val == 150) // motor #1 forward
digitalWrite(pin1, HIGH);
digitalWrite(pin5, HIGH);
else if (val == 200) // motor #2 reverse
digitalWrite(pin4, HIGH);
digitalWrite(pin8, HIGH);
else if (val == 250) // motor #2 stop
else if (val == 300) // motor #2 forward
digitalWrite(pin3, HIGH);
digitalWrite(pin7, HIGH);
else if (val >= 1000 && val <= 1255)
analogWrite (pw1 and pw3, val - 1000);
else if (val >= 2000 && val <= 2255)
analogWrite (pw2 and pw4, val - 2000);
I would like to focus on the last couple of lines. My values are derived from buttons off an application on MIT app inventor so no worries about the numbers. So i have two sliders on the app and I want them to control each side of my RC car like a skid steer. so motors 1/3 and 2/4 produce the same speed. I didn’t know the correct way to express this so I made " analogWrite (pw2 and pw4, val - 2000); "
when I tested this, all the motors would just beep and not move.
does anyone know how to, actually, make pw2/4 the same and pw1/3 the same?
