Skinner Box
Hi guys!
I'm trying to build a Skinner Box (an apparatus used to study behavior in animals) controlled by Arduino.
So, the system is as follows:
The animal press a lever for 2 seconds to light an LED randomly (left or right) for 1 second to indicate where the animal should go to get a reward. For this last point the animal should break an IR beam, to activate a solenoid valve in the side where the LED was lit.
Well, I´m new in Arduino, and the part of the IR beam doesn´t work :~
Can you help me please???
Thank you!
One trial is iniciated when a switch (lever) is pressed for 2 seconds, then one of two LEDs is randomly turned on (cue) for 1 second
indicating the side where a rat must interrupt an IR beam in order to receive a drop of water (delivered with a solenoid valve). If the rat
interrupts the incorrect IR beam nothing happens until she press the switch again.
//Declare variables:
unsigned long keyPrevMillis = 0;
const unsigned long keySampleIntervalMs = 25;
byte longKeyPressCountMax = 80;    // 80 * 25 = 2000 ms
byte longKeyPressCount = 0;
byte prevKeyState = HIGH;                           // switch is active low
const byte keyPin = 8;                              // switch is connected to pin 8 and GND
int LED1 = 12;
int LED2 = 13;
int IR_1 = 4;
int IR_2 = 5;
int valvePin1 = 6;
int valvePin2 = 7;
int emitter1 = 1;
int emitter2 = 2;
const int cant_LED = 2;                               // number of LEDs I have
const int cant_emitters = 2;                          // number of IR LEDs I have
int LEDs [cant_LED] = {LED1, LED2};
int emitters [cant_emitters] = {emitter1, emitter2};
//Is called when switch is pressed:
void LED(){
    digitalWrite (LEDs[random(cant_LED)], HIGH);                //An LED is turned on randomly (LED1 or LED2)
    delay(1000);                                                //for 1 sec
    for (int i=0; i < 2; i++) {
    digitalWrite (LEDs[i], LOW);                                //then is turned off
void IR(){
    byte beam1 = digitalRead (IR_1);
    byte beam2 = digitalRead (IR_2);
    if ((LED1 == HIGH) && ( beam1 == LOW)){                    //when LED1 was on and beam1 was interrupted
    digitalWrite (valvePin1, HIGH);                            //turn the valve1 on
    delay(1000);                                               // for 1 sec
    digitalWrite (valvePin1, LOW);                             // then turn it off
    Serial.print(",");
    Serial.println('delivered left');
  else if ((LED2 == HIGH) && ( beam2 == LOW)){                //when LED2 was on and beam2 was interrupted
    digitalWrite (valvePin2, HIGH);                           //turn the valve2 on
    digitalWrite (valvePin2, LOW);                            //then turn it off
    Serial.print(",");
    Serial.println('delivered right');
// Is called when switch is kept pressed for less than 2 seconds
void shortKeyPress() {
    Serial.println("short ----");
// called when switch is kept pressed for more than 2 seconds
void longKeyPress() {
    Serial.println("long ----");
    LED();
    IR();
// Is called when key goes from not pressed to pressed
void keyPress() {
    Serial.println("key press");
// Is called when key goes from pressed to not pressed
void keyRelease() {
    Serial.println("key release");
    if (longKeyPressCount >= longKeyPressCountMax) { //if the switch is pressed for at least 2 seconds call "longKeyPress"
        longKeyPress();
    else {                                          //otherwise "shortKeyPress" is called.
        shortKeyPress();
    pinMode(keyPin, INPUT_PULLUP);                 // switch is an input
        for (int i=0; i < cant_LED; i++) {         // LEDs are outputs
    pinMode(LEDs[i], OUTPUT);
        for (int i=0; i < cant_emitters; i++) {
    pinMode(emitters[i], OUTPUT);                  //
    digitalWrite (emitters[i], HIGH);              // both IR emitters are always on
    pinMode (IR_1, INPUT);                         //
    pinMode (IR_2, INPUT);                         // IR receptors are inputs
    pinMode (valvePin1, OUTPUT);
    pinMode (valvePin2, OUTPUT);                   // Valve pins are outputs
    // key management section
    if (millis() - keyPrevMillis >= keySampleIntervalMs) {
        keyPrevMillis = millis();
        byte currKeyState = digitalRead(keyPin);                     //currKeyState reads the state of the switch
        if ((prevKeyState == HIGH) && (currKeyState == LOW)) {       // if the switch is pressed
            keyPress();                                              //call "keyPress"
        else if ((prevKeyState == LOW) && (currKeyState == HIGH)) {  //if the switch is released
            keyRelease();                                            //call "keyRelease"
        else if (currKeyState == LOW) {
            longKeyPressCount++;
        prevKeyState = currKeyState;
We probably need a schematic and part number for how you hooked it up.
And you are using your definitions for the pins for the lights as a variable to determine its state. That won't work, as it will always respond the same (I'm not sure if (12 == HIGH) will evaluate to 0 or 1) but you probably want to do something like
digitalRead(LED1) == HIGH instead.
You mean something like "ledState"?
let me draw that in fritzing...
