Skipped Keypad inputs
My project is simulating a security system that has a PIR Movement sensor, and once it senses movement a buzzer goes off, a LCD shows the alarm is going off, and 2 LED lights blink back and forth. I have a keypad to read in a password however it seems that the user would need to press the button at the exact time as the code in the loop. Does anybody have any solutions?
Here's the code:
#include <Keypad.h>
#include <LiquidCrystal.h> // For LCD
int LED_1=23; //LED 1
int LED_2=25; //LED 2
int readyLED=24;
int motionS=52; //PIR Motion sensor
int detection;
//PIR output storage
int PIR_store=0;
int screenOffMsg=0;
String password="8900";
String tempPassword;
boolean enteredPassword;
long hold; //duration
boolean activateAlarm=false;
boolean alarmActivated=false;
boolean activated=false;
const byte Rows=4;
const byte Col=4;
char keypressed; //Keypad inputs
char keyMap[Rows][Col]= {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
const byte Rowpins[Rows]= {14,15,16,17};
const byte Colpins[Col]= {18,19,20,21};
#define buzzer 38
Keypad myKeypad= Keypad(makeKeymap(keyMap) , Rowpins, Colpins, Rows, Col);
LiquidCrystal lcd(2,3,4,5,6,7);
pinMode(LED_1, OUTPUT);
pinMode(LED_2, OUTPUT);
pinMode(motionS,OUTPUT);
pinMode(readyLED,OUTPUT);
pinMode(motionS,INPUT);
pinMode(buzzer,OUTPUT);
lcd.begin(16,2);
void Blink() //Flashing LED Lights when Motion is detected
 if(activated)
     digitalWrite(LED_1,HIGH);
     delay(400);
     digitalWrite(LED_1,LOW);
     digitalWrite(LED_2,HIGH);
     delay(400);
     digitalWrite(LED_2,LOW);
void passCode() //Passcode function
 int k=6;
 tempPassword = "";
 //activated = true;
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print(" *** ALARM *** ");
 lcd.setCursor(0,1);
 lcd.print("Pass>>");
     while(activated) {
      Blink();
     keypressed = myKeypad.getKey();
     tone(buzzer,200);
     if (keypressed != NO_KEY){
       if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' ||
           keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' ||
           keypressed == '8' || keypressed == '9' ) {
         tempPassword += keypressed;
         lcd.setCursor(k,1);
         lcd.print("*");
         k++;
     if (k > 10 || keypressed == '#') {
       tempPassword = "";
       k=6;
       lcd.clear();
       lcd.setCursor(0,0);
       lcd.setCursor(0,1);
     if ( keypressed == '*') {
       if ( tempPassword == password ) {
         activated = false;
         alarmActivated = false;
         noTone(buzzer);
         screenOffMsg = 0;
         lcd.clear();
         lcd.setCursor(3,0);
         lcd.print("DISARMED");
         delay(2000);
         PIR_store=0;
       else if (tempPassword != password) {
         lcd.setCursor(0,1);
         lcd.print("Incorrect Pass");
         delay(2000);
         lcd.clear();
         lcd.setCursor(0,0);
         lcd.setCursor(0,1);
 if(alarmActivated!=1) //LCD options screen
   lcd.setCursor(1,0);
   lcd.print("Press A to");
   lcd.setCursor(5,2);
   lcd.print("Activate");
   keypressed=myKeypad.getKey();
   if(keypressed=='A') //Activating Alarm
      activateAlarm=true;
 if (activateAlarm==true)
   lcd.clear();
   lcd.setCursor(1,0);
   lcd.print("Alarm will be");
   lcd.setCursor(1,1);
   lcd.print("activated in");
   int countdown=30; //30 second countdown
   while(countdown!=0)     //Alarm activation countdown
     lcd.setCursor(14,1);
     lcd.print(countdown);
     --countdown;
     if(countdown<9)
      countdown++;
      lcd.print(" ");
      lcd.setCursor(15,1);
      countdown--;
     tone(buzzer,600,100);
     digitalWrite(readyLED,HIGH);
     delay(300);
     digitalWrite(readyLED,LOW);
   lcd.clear();
   lcd.setCursor(3,0);
   lcd.print("ACTIVATED !");
   delay(2000);
   lcd.clear();
   alarmActivated=true;
  if(alarmActivated==true)
  PIR_store= digitalRead(motionS);
  lcd.setCursor(2,0);
  lcd.print("*HOUSE ARMED*"); //Activation is fully set
  if(PIR_store==1)  //Motion detector senses a motion and sets off alarm
    while(PIR_store==1)
     activated=true;
      Blink();
      passCode();
If you want a responsive program you need to get rid of all the delay()s as they block the Arduino from doing other things. Have a look at how millis() is used to manage timing without blocking in Several Things at a Time.
And see Using millis() for timing. A beginners guide if you need more explanation.
To make it easy for people to help you please modify your post and use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
It is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. Just use cstrings - char arrays terminated with 0.
...R
