Skipping If Statement
Hello Guys,
I have been trying for hours and hours to sort out this issue but apparently I can't and for the life of me I cannot understand why and that's why I am asking for your help. Thanks in Advance.
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
//Global Variables
String adminName = "Lelz";
String realName = "Lelz";
String nick = "Lelz";
String chan = "#NesquickBotTesting";
byte mac[] = {0x90, 0xA2, 0xDA, 0x00, 0xDE, 0x0B};//mac address for [my] sheild
//char server[] = "irc.chat.twitch.tv"; //can also be a byte[] with a direct IP address
char server[] = "chat.freenode.net";
//byte server[] = {54,148,142,141};
byte ip[] = {192, 168, 0, 177};
EthernetClient client;
//definitions
int connectToServer();
//let's go
  Serial.begin(250000);//Start the serial - useful for debugging purposes
  //Start the connection to the IRC server
  pinMode(24, OUTPUT);
  if (Ethernet.begin(mac) == 0)
    Ethernet.begin(mac, ip);//if we can't get an IP address, we'll force one.
  delay(2000);//Give a couple of seconds to allow the ethernet board to initialize.
  if (connectToServer() == 0)
    Serial.println("Connection to server FAILED! Entering infinite loop. Please reset the Arduino and try again.");
    for (;;)
      //do nothing until arduino is reset. Basically an infinite loop.
  bool sendRegInfo = true;
  bool newLine = false;
  String messageReceived = "";
  String messageToSend = "";
  char c;
  char d;
  String serialInput = "";
  while (client.connected())
    c = client.read();
    if (Serial && Serial.available() > 0)
      serialInput = Serial.readStringUntil('\n');
    if (c != -1)//If we read a valid character (That is, client.read() gives us something to work with). -1 is returned when nothing is read.
      messageReceived += c;
    if (c == '\n')
      int commaIndex = messageReceived.indexOf('!');
      int secondCommaIndex = messageReceived.indexOf('!', commaIndex + 1);
      String firstValue = messageReceived.substring(0, commaIndex);
      String secondValue = messageReceived.substring(commaIndex + 1, secondCommaIndex);
      String thirdValue = messageReceived.substring(secondCommaIndex + 1);
      Serial.println("Isto e firstValue:   " + firstValue);
      Serial.println("Isto e secondValue:   " + secondValue);
      Serial.println("Isto e thirdValue:   " + thirdValue);
      String LEDON = "lon";
      String LEDOFF = "loff";
      if (thirdValue.equals(LEDON)) {
        Serial.println("ONNNNNN");
        digitalWrite(24, HIGH);
      } else if (thirdValue.equals(LEDOFF)) {
        Serial.println("OFFFFFF");
        digitalWrite(24, LOW);
      Serial.print(messageReceived); //NOT println because the carriage return already exists in the string sent from the server.
      newLine = true;
    if (sendRegInfo)
      client.println("USER " + nick + " * 0 :" + realName);
      client.println("NICK " + nick);
      client.println("JOIN " + chan);
      sendRegInfo = false;
    if (newLine)//if we have a string to process...
      if (messageReceived.startsWith("PING"))
        messageToSend = messageReceived;
        messageToSend.replace("PING", "PONG");
      if (messageReceived.indexOf("PRIVMSG " + nick + " :QUIT") > messageReceived.indexOf(":" + adminName)) // Quit in query
        messageToSend = "QUIT";
      newLine = false;
    else if (serialInput != "")
      messageToSend = "PRIVMSG " + chan + " :" + serialInput;
      serialInput = "";
    if (messageToSend != "")
      client.println(messageToSend);
      Serial.println("OUTPUT: " + messageToSend);
      messageToSend = "";
  Serial.println("Connection is gone. Quitting...");
  for (;;)
    //end on infinite loop.
  if (Serial)
    Serial.println("Connecting to the IRC server...");
  if (client.connect(server, 6667))
    return 1;
  else return 0;
My problem is on the IF statement that turns the LED ON/OFF. For some reason it doesn't turn on/off even though the thirdValue variable contains the right word which is "lon" "loff".
Can someone give me some sort of help?
Best Regards
Nesquick
    c = client.read();
Why is receiving serial data dependent on their being a client connected?
The index does NOT point to a comma!
Are you CERTAIN that the variable doesn't contain "lon\r" or "loff\r"?
Print the value better to be sure.
Serial.print("thirdValue: [");
Serial.print(thirdValue);
Serial.println("]");
Do you see
thirdValue: [lon]
or
thirdValue: [lon
Hello,
Thanks for your reply.
1- I think there is no point to receive serial data if the client is disconnected. I am right?
2- I know that the index point to an Exclamation mark, I forgot to change the variable name.
3- This is what i get, and I can see the problem. there is a /n at the end of the "lon" and thats why its not working properly. I am correct?
thirdValue: [lon
Best Regards
Nesquick
No. The serial data isn't coming from the client.
It is a line feed, since you are dealing with the carriage return. You can use String::trim() to get rid of it (or not store it in the first place).
