SKM53 gps module issue: parsing data
Hello
I am doing project with chipkit wi-fire but i am using Arduino IDE for programming it. I am using GPS module SKM53 with TinyGPS library to get latitude and longitude.
I am using the example form that library. Here is the code:
TinyGPS gps;
SoftwareSerial ss(1, 0);
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.println("Sats HDOP Latitude  Longitude  Fix  Date       Time     Date Alt    Course Speed Card  Distance Course Card  Chars Sentences Checksum");
  Serial.println("          (deg)     (deg)      Age                      Age  (m)    --- from GPS ----  ---- to London  ----  RX    RX        Fail");
  Serial.println("-------------------------------------------------------------------------------------------------------------------------------------");
  ss.begin(9600);
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
  print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
  gps.f_get_position(&flat, &flon, &age);
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 11, 6);
  print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
  print_date(gps);
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 7, 2);
  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
  print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
  print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0xFFFFFFFF : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? TinyGPS::GPS_INVALID_F_ANGLE : TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
  print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
  gps.stats(&chars, &sentences, &failed);
  print_int(chars, 0xFFFFFFFF, 6);
  print_int(sentences, 0xFFFFFFFF, 10);
  print_int(failed, 0xFFFFFFFF, 9);
  smartdelay(1000);
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
  if (val == invalid)
    while (len-- > 1)
      Serial.print('*');
    Serial.print(' ');
    Serial.print(val, prec);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1); // . and -
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(' ');
  smartdelay(0);
  char sz[32];
  if (val == invalid)
    strcpy(sz, "*******");
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  smartdelay(0);
  int year;
  byte month, day, hour, minute, second, hundredths;
  unsigned long age;
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  if (age == TinyGPS::GPS_INVALID_AGE)
    Serial.print("********** ******** ");
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",
        month, day, year, hour, minute, second);
    Serial.print(sz);
  smartdelay(0);
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  smartdelay(0);
I am using 9600 baud for gps and 115200 for serial connection.
the output in 115200 baud rate is like this:
Testing TinyGPS library v. 13
by Mikal Hart
------------------------------------------------------------------------------------------------------------------------------ÿ
after that it stops posting any value.
In 9600 baud rate the output of gps nmea code is displayed like this:
$GPGGA,173458.000,5133.4150,N,00014.8604,W,2,7,0.96,33.2,M,47.0,M,0000,000073
$GPGSA,A,3,14,25,19,24,02,29,31,,,,,,1.28,0.96,0.85
0C
$GPGSV,3,1,12,12,70,060,,25,69,263,23,14,49,275,24,24,41,128,3170
$GPGSV,3,2,12,49,30,173,35,29,21,192,32,19,20,043,17,06,19,061,77
$GPGSV,3,3,12,02,18,103,26,31,13,300,15,22,06,307,,03,02,357,72
$GPRMC,173458.000,A,5133.4150,N,00014.8604,W,0.00,154.96,070316,,,D
72
$GPGGA,173459.000,5133.4150,N,00014.8604,W,2,7,0.96,33.2,M,47.0,M,0000,0000
72
0C
$GPGSV,3,3,12,02,18,103,27,31,13,300,14,22,06,307,,03,02,357,72
$GPRMC,173459.000,A,5133.4150,N,00014.8604,W,0.00,154.96,070316,,,D
73
$GPGGA,173500.000,5133.4150,N,00014.8604,W,2,7,0.96,33.2,M,47.0,M,0000,0000
7F
0C
$GPGSV,3,1,12,12,70,060,,25,69,263,23,14,49,275,24,24,41,128,32*73
$GPGSV,3,2,12,49,30,173,35,29,21,192,32,19,20,043,16,06,19,061,76
$GPGSV,3,3,12,02,18,103,27,31,13,300,13,22,05,307,,03,02,357,76
$GPRMC,173500.000,A,5133.4150,N,00014.8604,W,0.00,154.96,070316,,,D
7E
$GPGGA,173501.000,5133.4150,N,00014.8604,W,2,7,0.96,33.2,M,47.0,M,0000,0000
7E
Can anyone please help me fix or guide me to correct way in solving this problem?
(deleted)
Thank you! spycatcher2K!
the problem was i was not able to get the latitude and longitude.
After using pin 2 and 3, i got the latitude and longitude and everything, all working fine.
Thank you!
