Skyetek M1 mini RFID reader
Hello World :D,
I'm in a cool project from school for blind and visually impaired people. I'm trying to make a RFID reader connected with an Arduino BT, a little motor and a piëzo element.
I also have an Arduino w/ a serial USB port and an Atmega8-16PU for testing.
Everything is working great...the motor, the leds, even melodies on the piëzo element, BUT!! :frowning:
My problem is that the ports 0 RX and port 1 TX on the Arduino not really communicate w/ the Skyetek module or the other way ;).
Here is the SkyeModule M1-Mini Product Reference Guide
Can anybody help me please...i'm really stuck @ this moment >:(
Thnx,
Michel
hi
one hint: you will have to use software serial, as you can't conect it to the HWserial port on the BT, as it's used for the Bluetooth communication.
D
Thnx for the quick reply...
It helped me a lot, but it's still not working...
How can I send commands from the Arduino to my Skyetek RFID reader.
The readTag command for the reader is 0x24.
I also want to know how I can check the data that the Arduino is recieving.
I already tried the Arduino Software Serial Interface page but it seems that it is not possible to send data trough the tx port.
Does their exist an Serial write or something??
Michel
Here's the software serial reference page
I allready tried this page...but my Skyetek reader is still not communicate w/ the arduino.
What I want is to program some code on the Skyetek reader trough the arduino to activate the Skyetek reader...
Can I do that??
I've searched the forum and can't find any reference to "Skyetek" specifically, unfortunately not all devices work out-of-the-box with Arduino, though the Skyetek data sheet makes it sound simple, its probably not.
That's the reason why I posted, lol :smiley:
The problem is that when I put this code in Arduino.
#include <SoftwareSerial.h>
#define rxPin 3
#define txPin 2
#define ledPin 13
// set up a soft serial port
SoftwareSerial mySerial(rxPin, txPin);
byte pinState = 0;
void setup()  {
  // define pin modes for tx, rx, led pins:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  // set txPin high (as recommended in forum)
  digitalWrite(txPin, HIGH);
  // set the data rate for the serial ports
  mySerial.begin(9600);
  // say something
  Serial.println("Hello World!");
  byte someChar = 0;
  someChar = mySerial.read();
  // print out the character:
  Serial.print(someChar, HEX);
  // toggle an LED just so you see the thing's alive.
  // this LED will go on with every OTHER character received:
  toggle(13);
void toggle(int pinNum) {
  // set the LED pin using the pinState variable:
  digitalWrite(pinNum, pinState);
  // if pinState = 0, set it to 1, and vice versa:
  pinState = !pinState;
When I monitor this code, I get
Hello World
EE46DA ---->This is a random number
This happens without touching any tag, when I disconnect the tx wire, there's a lot of zero's with sometimes hex numbers trough it.
Can anybody tell me, how I can see if the RFID reader is sending any info from the tag??
Try reading through what others have done with different hardware devices, the Skyetek hasn't been done by anyone else so there's no off-the-shelf answers. Some people spend days just wiring LEDs to blink on and off, weeks or months with more complex devices - even when there's references available.
I know if you dig deep enough, you'll find the answers your looking for :slight_smile:
Thanks, but I'm looking very deep.
The Skyetek reader is not that different component then the kind of components that are on this forum. Its just an extra component on the Arduino! Is there not any component that needs to be programmed by the Arduino board??? Because thats what I like to know.
Can you program code on the arduino that program another chip that's only using a TTL connection??
this what i got till now...but still not working
#define txPin 5
#define rxPin 4
#define ledPin 13
// create some space for receiving data from tag reader
#define d_size 64
byte dta[ d_size];
Serial.println("begin ");
int in_count;
// send command
mySerial.print( 0x0d, BYTE); //send CR
mySerial.print( "0");
mySerial.print( "1");
mySerial.print( "4");
// get first byte of answer
byte ch = mySerial.read();
// if it was not a LF, send read command again
// if it was, store all bytes until ending LF was received
//Serial.println(ch, HEX);
//Serial.println(d_size, HEX);
if (ch == 0x0a)
Serial.println(" if ");
in_count = 0;
while( (ch != 0x0a) && ( in_count < d_size))
Serial.println(" while ");
dta[in_count] = ch;
in_count++;
// and print the received characters to Serial
for ( int i = 0; i < in_count; i++) Serial.print( dta*, BYTE);*
  • Serial.println();*
How is it wired up? You do have RX and TX crossed (so Arduino's TX goes to RFID's RX and vice versa) right?
of course...and also switched these many times... ::slight_smile:
#define txPin 5
#define rxPin 4
#define ledPin 13
#define d_size 64
byte dta[ d_size];
int in_count;
// send command
if (ch == 0x0a)
in_count = 0;
dta[in_count] = ch;
in_count++;
  • Serial.println(); *
    ITS finally working....!!! ;D :smiley: :sunglasses:
