skylab skm53 not returning any data
I bought a Skylab skm53, but i cant get it to return anything.
Ive connected it up as they describe where i bought it: http://www.ebay.com/itm/Skylab-UART-Serial-GPS-Module-for-Arduino-uController-with-Breakout-Board-Pins-/301108474787?hash=item461b76b3a3:g:AJ0AAOxy--NRntzt
VCC to 5V
GND to GND
TX to D2
RX to D3
ive tested it a bit, but it wont do anything.
Its not the code, because the problem is that TXD on the GPS is always low.
So im just wondering if anyone in here has a solution of some kind.
"It's not the code because I like chocolate ice cream" would make as much sense. How do you KNOW that the TX pin is always low?
The time that the pin is high to transmit a byte will not register on a multimeter.
Because I wired the gps TXD directly to rx(D0) on the arduino afterwards to see if I was able to get plain gps data on the monitor, but I wasn't
Got it working however i am reciving some very strange data. It is giving very little sence like half of the returned data is changed to ÿÿÿÿ.
#include <SoftwareSerial.h>
#define RXPIN 4
#define TXPIN 3
SoftwareSerial gps(RXPIN, TXPIN);
  gps.begin(9600);
  while (gps.available())
      char c = gps.read();
      Serial.write(c);
ÿ‚‚±5%2¹3766,N,01b8.72,EX.00,28ÿÿÿÿÿÿÿÿÿÿÿïÿÿÿÿÿÿÿÿÿÿÿÿÿ÷ÿÿÿÿÿÿÿÿßÿÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿýÿÿÿÿÿÿÿÿÿÿÿÿý÷ÿÿÿÿÿÿýÿÿÿÿÿÿÿÿÿÿÿÿÿßÿwÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿÿÿßÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿÿ¿ÿ÷ÿþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿÿÿÿÿÿÿÿþÿÿÿþÿÿÿïÿÿÿÿÿÿÿ÷ÿÿÿÿÿýÿÿÿÿÿÿÿÿþÿÿÿÿÿÿÿ÷ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿÿÿÿÿþÿÿÿ¿÷ÿÿÿÿÿÿÿÿ‚±ŠDä4º²²ÄÉŠ Š.‚Ârº‚±2$8,bs’‚b±¢‚‚b‚‚
$GPGSA,A,3507,,,1.2d¹0509
3,1,12,,70X8hcšbªbª ²ºbDj GP�¦Y±šb$bŠ’bÂb�²bb*bŠªj¤$GPGSV,3,3,12c‚’’ºŠ‰I“)b‚!¤JUj±bÅ4846.000,A,5520,3766,N,01107,316,ÿÿÿÿÿÿÿýÿÿÿÿÿÿÿ÷ÿýÿÿÿýÿÿÿÿÿÿÿÿþÿÿÿÿÿ¿ÿÿÿÿÿÿÿÿÿÿÿÿÝÿÿÿÿÿÿÿÿÿÿÿÿÿßÿÿÿÿûÿÿÿ¿ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿþÿÿÿÿÿÿÿÿÿÿ÷ÿÿÿßÿÿÿÿÿÿÿÿÿÿûÿÿÿ÷ÿÿÿÿÿÿïÿþÿÿÿþÿÿÿÿÿÿ÷ÿÿÿÿÿÿÿÿïÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ¿ÿÿArršª²²ÄdŠ Q.Ârº‚¢’b
Å‚bšb²±43.6,M,00±±3,05(09,27,28085,3,1.j0#
ÅbŠÄ ªÄ’ºbD‚b€²Š˜GPG¦V,f,2,12,28,38,08,2‹ŠÒuM²bšb4b.“‰ ÂbŠ¢b‚ª¢b’bŠ’Bš’.b‚�¢bŠ’‚ $GPRM bŠŠ¢b*®’š±0bb08\Ý042,E,0\Á0Xd.40,080#1,D*6b ÿ÷ÿÿÿÿÿÿÿÿýÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿýÿ÷ÿÿÿ÷ÿÿÿÿÿÿÿý¿ÿýÿÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿÿþÿÿÿÞÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿïÿÿÿÿÿÿÿÿÿÿÿÿÿÿþïÿ÷ÿÿÿÿÿÿÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿÿýÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿïÿÿÿþÿÿÿÿÿÿÿG,11020.3767042,.2.6,š,00 A,A,0,30,,1.22.06ÄÄ’bºbŠšb©¡šb’’b‚²ºb¢‚
$GPFSVX3Xd,12,28, ²bbŠªbŠªH’Ž Âb¢bŠ’Âbb¢b’ªb‚j$$GPM†X11484.000,,5523'll,N,018.7‚r‚‰Éÿÿû÷ÿÿÿÿÿÿþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿýÿÿÿÿÿÿîÿÿÿÿÿÿþÿßÿÿÿûÿÿÿÿÿÿÿßÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿÿÿÿþÿÿÿÿ÷ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿÿÿþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿýÿÿÿÿÿÿþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿÿÿÿÿGA bŠŠ¢Â¢Ê&LiÓ“Š S¹LÂrº‚¢’b*Å’bÂbŠÎIb²äbjÅ¢šrd‚‚b‚‚‚5 $GPGSA,05XÁ8,13,20,,,,006*A
$MbbB4b’’’b’ “Hˆ‰IbŠ’ÂbbÊ¢‚bŠbj
$GPGSV,3,3,1,14,02 ’¢bb
$ŽPRMCX1148h9.00±A,jj20.37660110±0.00,2.h,0803bl,X±D
6F
ÿÿïßÿÿÿïÿÿÿÿÿÿÿÿÿÿßÿÿÿÿÿÿþÿÿÿÿÿÿÿÿÿÿÿïÿÿÿÿÿÿÿÿÿÿÿÿûÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿïÿÿÿÿÿÿÿÿ¿ÿÿÿÿþÿÿÿýÿÿÿÿÿÿþÿÿÿÿÿÿÿÿÿ÷ÿÿþÿÿÿ÷ÿÿÿÿÿÿöûÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ÷þÿÿÿÿÿÿþÿÿÿÿÿÿÿÿÿÿÿÿÿÿÔ±bÅ4850\000,5420.37lÙ,N,01108.7042,E.3.6000,5
$GPG3,0,18,07Ä$ršÉ“ S5R$GPG¦Y±ÍbŠbŠ’bš‚bº‚b‚Ži‰)ÓbŠ¢b’¢©4b’‰ ²ºb¢‚RÔb’bbŠÉ)b’’b$Š‚bŠj
$Ž@MYbšbšb‰)¢Äbš’ÂbŠŽ ’¢b’Db‚é’j¤$GPRMC,b…4pj`¹000,A,52Áršºd²br‚
‰©b‚r‚‚b’r¢‚‚©lÝ
The default baudrate is 9600. Ive tried 4800 but it looks even worse :confused:
Fix: connect rx and tx through an recister
