SkyNav SKM53 GPS
i want to modify this code to show lon,lat direct to send it by gsm
the output
Latitude : 0.0000000 :: Longitude : 0.0000000
i want to show lat,lon , if lat,lon have value only.
#include <TinyGPS.h>
#include <SoftwareSerial.h>
unsigned long fix_age;
SoftwareSerial GPS(2,3);
TinyGPS gps;
void gpsdump(TinyGPS &gps);
bool feedgps();
void getGPS();
long lat, lon;
float LAT, LON;
void setup(){
  GPS.begin(9600);
void loop(){
  long lat, lon;
  unsigned long fix_age, time, date, speed, course;
  unsigned long chars;
  unsigned short sentences, failed_checksum;
  // retrieves +/- lat/long in 100000ths of a degree
  gps.get_position(&lat, &lon, &fix_age);
  getGPS();
  Serial.print("Latitude : ");
  Serial.print(LAT/1000000,7);
  Serial.print(" :: Longitude : ");
  Serial.println(LON/1000000,7);
void getGPS(){
  bool newdata = false;
  unsigned long start = millis();
  // Every 1 seconds we print an update
  while (millis() - start < 1000)
    if (feedgps ()){
      newdata = true;
  if (newdata)
    gpsdump(gps);
bool feedgps(){
  while (GPS.available())
    if (gps.encode(GPS.read()))
      return true;
  return 0;
  //byte month, day, hour, minute, second, hundredths;
  gps.get_position(&lat, &lon);
  LAT = lat;
  LON = lon;
    feedgps(); // If we don't feed the gps during this long routine, we may drop characters and get checksum errors
You seem to be printing the LAT and LON variables but never changing their values.
Latitude : 29.9746150 :: Longitude : 31.2454032
the output now
I want to modify the code , if there's no change in values, the code don't print values,and waiting to new value..
My apologies. I can see where LAT and LON are updated.
Floats are notoriously difficult to compare because of how they are stored and calculated. How much of a change in value constitutes “no change in value”. Working to that many decimal places with floats is likely to result in a slightly different reading each time.
UKHeliBob:
Floats are notoriously difficult to compare because of how they are stored and calculated. How much of a change in value constitutes "no change in value". Working to that many decimal places with floats is likely to result in a slightly different reading each time.
in the first of serial monitor,output
then
the right location
That is because it takes a while for the GPS device to start working, it has to download information from the satellites first.
As an experiment, after you print LAT and LON save LAT/10000 and LON/10000 in 2 new variables. Before you print them again test the new values of LAT/10000 and LON/10000 against the previous ones and only print if either of them has changed.
