Hi everyone,
I must apologize, I am very new with this stuff, but I'm learning as I go so try to bear with me. I am trying to get a DLP printer up and running using Marlin firmware. I already installed the correct package for DLP printers and moved the files and folders to the proper locations (for overwriting). I also changed any settings that were required. Here is a detail of my specs:
Hardware:
- iPad3 (mask)
- Xbox 360 12V DC power supply
- Arduino Mega 2560
- RAMPS 1.4 Board (Z-axis motor control)
- Abusemark LCD Adapter (display)
- 3W LEDs with LED dimmer driver (light projection)
Software:
- Creation Workshop
- Arduino / Marlin
I was able to successfully upload the firmware to the Arduino, however, before I did so I uploaded the firmware to the wrong port on my laptop, which consisted of the power to the LCD adapter controller.
I'm hoping this didn't wreck the controller... anyways, that seems to be the case, because now when I connect the Displayport cable to my laptop from the adapter, the screen goes completely black and I can't revert it back to normal without unplugging the cable.
Also even after following all of the instructions on the documentation from mUVe 3D for a DLP printer, the motors aren't responding to the Z-HOME command.
If any of you have an idea what I should do to fix these problems, it would be much appreciated. Thanks!
Ian
