I'm struggling to get a grip on using WDT to wake up from sleep in the same sketch as a PCINT interrupt
my aim is for the WDT to wake every second, with the PCINT just counting interrupts in the background
my sketch wakes successfully every second on the WDT, as long as there are no interrupts
if there are interrupts, it seems to not wake up
what I suspect is happening is I am managing to reset the clock every interrupt
so it doesn't get the chance to timeout
code is here:
main sketch
const byte LED = 6;
extern boolean wdtFlag;
extern boolean windFlag;
// setup
void setup(void)
Serial.begin(57600);
Serial.println("sleep.wake.tester");
pinMode(LED, OUTPUT);
flash();
windInit();
sleep(true);
// loop
void loop(void)
if (wdtFlag)
Serial.print('D');
Serial.flush();
flash();
wdtFlag = false;
sleep(true);
if (windFlag)
Serial.print('W');
Serial.flush();
windFlag = false;
sleep(false);
void flash(void)
// flash LED
for (byte i = 0; i < 1; i++)
digitalWrite (LED, HIGH);
delay (50);
digitalWrite (LED, LOW);
delay (50);
sleep stuff is here:
#include <avr/sleep.h>
#include <avr/wdt.h>
boolean wdtFlag;
// prepare the watch dog timer and sleep
void sleep(boolean start)
// on entry
// true = start the clock
// false = leave clock running
Serial.println('s');
Serial.flush();
// set interrupt mode and interval
// WDP3 WDP2 WDP1 WDP0 timer ~seconds
// 0 0 0 0 16 mS
// 0 0 0 1 32 mS
// 0 0 1 0 64 mS
// 0 0 1 1 128 mS 0.125
// 0 1 0 0 256 mS 0.25
// 0 1 0 1 512 mS 0.5
// 0 1 1 0 1024 mS 1
// 0 1 1 1 2048 mS 2
// 1 0 0 0 4096 mS 4
// 1 0 0 1 8192 mS 8
MCUSR = 0;
if (start)
// starting the timer
// clear various "reset" flags
if (start)
// allow changes, disable reset
WDTCSR = bit (WDCE) | bit (WDE);
// wdt enabled and 1 second timer
WDTCSR = bit (WDIE) | bit (WDP2) | bit (WDP1);
// call reset
wdt_reset();
// set sleep mode
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
// disable ADC
ADCSRA = 0;
// turn off brown-out enable in software
MCUCR = bit (BODS) | bit (BODSE);
MCUCR = bit (BODS);
// sleep...
sleep_mode();
// ... and wake-up
// disable the timer
sleep_disable();
// enable ADC
ADCSRA |= _BV(ADEN);
Serial.print('w');
Serial.flush();
// watchDogTimer interrupt
ISR(WDT_vect)
// just set the watchdog flag
wdtFlag = true;
and finally the interrupt:
// wind
#define WINDSPEEDPIN 3
// flag to show interrupt was from wind
boolean windFlag;
// interrupt handler for wind ticks
void handleWindTick()
// simply increment the counter
windFlag = true;
// routine to initialise wind sensors
void windInit(void)
pinMode(WINDSPEEDPIN, INPUT_PULLUP);
// INT1 => D3
attachInterrupt(1, handleWindTick, LOW);
// ensure interrupts are enabled
interrupts();
windFlag = false;
Serial.print('w');
with no interrupts I get
wDs
with the LED flashing every second
with interrupts I get
wWs
with no LED, until I stop the interrupts, when it reverts to flashing correctly
I would be delighted if someone could cast an eye and tell me where I have been a plonker!
thanks
