Sleep and wake with external interrupt
(Sorry I have had to do this in 2 posts. Apparently I have exceeded the maximum size limit for a post)
Hey all :slight_smile: . I am very new to this and a little confused about how somethings work. First some background. I have bullt a data logger with an arduino nano, an RTC (DS3231), a micro SD module, and a solenoid. Basically I would like my device to log sensor data to the SD card and If the sensor returns a certain value I would like it to open up the solenoid for 10 seconds. Here is my code and it is working perfectly.
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClibExtended.h"
// A simple data logger for the Arduino analog pins
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL  3000 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL 5000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
// The analog pins that connect to the sensors
#define Voltage A1                // analog 1
int solenoidPin = A3;    //This is the output pin on the Arduino we are using
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
  Serial.print("error: ");
  Serial.println(str);
  while(1);
void setup(void)
#if WAIT_TO_START
  Serial.println("Type any character to start");
  while (!Serial.available());
#endif //WAIT_TO_START
 pinMode(solenoidPin, OUTPUT);           //Sets the pin as an output
  // initialize the SD card
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    error("Card failed, or not present");
  Serial.println("card initialized.");
  // create a new file
  char filename[] = "ETC2.CSV";
  //for (uint8_t i = 0; i < 100; i++) {
    //filename[6] = i/10 + '0';
    //filename[7] = i%10 + '0';
    //if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      //break;  // leave the loop!
  if (! logfile) {
    error("couldnt create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
    logfile.println("RTC failed");
#if ECHO_TO_SERIAL
    Serial.println("RTC failed");
#endif  //ECHO_TO_SERIAL
  logfile.println("millis,stamp,datetime,voltage");
#if ECHO_TO_SERIAL
  Serial.println("millis,stamp,datetime,voltage");
void loop(void)
  DateTime now;
  // delay for the amount of time we want between readings
  delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
  // log milliseconds since starting
  uint32_t m = millis();
  logfile.print(m);           // milliseconds since start
  logfile.print(", ");
#if ECHO_TO_SERIAL
  Serial.print(m);         // milliseconds since start
  Serial.print(", ");
#endif
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(now.unixtime()); // seconds since 1/1/1970
  logfile.print('"');
  logfile.print(now.year(), DEC);
  logfile.print("/");
  logfile.print(now.month(), DEC);
  logfile.print("/");
  logfile.print(now.day(), DEC);
  logfile.print(" ");
  logfile.print(now.hour(), DEC);
  logfile.print(":");
  logfile.print(now.minute(), DEC);
  logfile.print(":");
  logfile.print(now.second(), DEC);
  logfile.print('"');
#if ECHO_TO_SERIAL
  Serial.print(now.unixtime()); // seconds since 1/1/1970
  Serial.print(", ");
  Serial.print('"');
  Serial.print(now.year(), DEC);
  Serial.print("/");
  Serial.print(now.month(), DEC);
  Serial.print("/");
  Serial.print(now.day(), DEC);
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(":");
  Serial.print(now.minute(), DEC);
  Serial.print(":");
  Serial.print(now.second(), DEC);
  Serial.print('"');
  analogRead(Voltage);
  delay(10);
  int tempReading = analogRead(Voltage);
  // converting that reading to voltage, for 3.3v arduino use 3.3, for 5.0, use 5.0
//  float voltage = tempReading * aref_voltage / 1024;
  float voltage = tempReading * (5.0 / 1023.0);
  logfile.print(voltage);
  logfile.println();
#if ECHO_TO_SERIAL
  Serial.print(", ");
  Serial.print(voltage);
  // Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
  // which uses a bunch of power and takes time
  if ((millis() - syncTime) < SYNC_INTERVAL) return;
  syncTime = millis();
  logfile.flush();
 if (tempReading <297) {
    digitalWrite(solenoidPin, HIGH);
    delay(10000); // time in milliseconds as parameter
    digitalWrite(solenoidPin, LOW);
So to save power I would like it to only log a few times an hour. 1 min of logging and then 10 min of sleep would be ideal. Although every half an hour or even once an hour would be acceptable if thats the way it has to be. So here is some code I have found to put the arduino to sleep.
#include <Wire.h>
#include <RTClibExtended.h>
#include <LowPower.h>
#define wakePin 2    //use interrupt 0 (pin 2) and run function wakeUp when pin 2 gets LOW
#define ledPin 13    //use arduino on-board led for indicating sleep or wakeup status
RTC_DS3231 RTC;      //we are using the DS3231 RTC
byte AlarmFlag = 0;
byte ledStatus = 1;
void wakeUp()        // here the interrupt is handled after wakeup
  //Set pin D2 as INPUT for accepting the interrupt signal from DS3231
  pinMode(wakePin, INPUT);
  //switch-on the on-board led for 1 second for indicating that the sketch is ok and running
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  //Initialize communication with the clock
  Wire.begin();
  RTC.begin();
  RTC.adjust(DateTime(__DATE__, __TIME__));   //set RTC date and time to COMPILE time
  //clear any pending alarms
  RTC.armAlarm(1, false);
  RTC.clearAlarm(1);
  RTC.alarmInterrupt(1, false);
  RTC.armAlarm(2, false);
  RTC.clearAlarm(2);
  RTC.alarmInterrupt(2, false);
  //Set SQW pin to OFF (in my case it was set by default to 1Hz)
  //The output of the DS3231 INT pin is connected to this pin
  //It must be connected to arduino D2 pin for wake-up
  RTC.writeSqwPinMode(DS3231_OFF);
  //Set alarm1 every day at 18:33
  RTC.setAlarm(ALM1_MATCH_SECONDS, 20, 0, 0, 1);   //set your wake-up time here
  RTC.alarmInterrupt(1, true);
  //On first loop we enter the sleep mode
    attachInterrupt(0, wakeUp, LOW);                       //use interrupt 0 (pin 2) and run function wakeUp when pin 2 gets LOW
    digitalWrite(ledPin, LOW);                             //switch-off the led for indicating that we enter the sleep mode
    ledStatus = 0;                                         //set the led status accordingly
    LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);   //arduino enters sleep mode here
    detachInterrupt(0);                                    //execution resumes from here after wake-up
//    When exiting the sleep mode we clear the alarm
   RTC.clearAlarm(1);
    AlarmFlag++;
  //cycles the led to indicate that we are no more in sleep mode
  if (ledStatus == 0) {
    ledStatus = 1;
  else {
    ledStatus = 0;
  delay(5000);
So my question is how do I integrate these 2 together? I am not sure where I put my code into the sleep code to get it to work. Also I am not sure how to set the interrupt to once every 10min instead of the same time every day like it is currently. Or even at the same time every hour would be okay if thats what I am limited too. I am also open to the idea of using a watchdog timer But i am very noob and at first glance it looked a little tricky to set up. Any help would be GREATLY appreciated thankyou!!
You can't use that code exactly as is. That code is designed to waken the CPU upon receipt of an external Signal. You are wanting to awaken the CPU based on time. The answer is something called the "Watchdog Interrupt" or "Watchdog Timer". Research that on the Forum and you will find tons of samples. Sometimes, it's just knowing what to look for.
Thanks for your reply. But i'm not sure we understand each other. I was wanting to send an external signal from the RTC (ds3231). I was under the impression that it kept the time independently of the nano and could send an interrupt?? Maybe I have misunderstood though.
DS3231 has alarms, yes?
"Two programmable time-of day alarms and a programmable square-wave output are provided."
Connect the INT/SQWV pin, with a pullup resistor, to an Arduino interrupt pin, and set the next alarm time to wake up after an alarm occurs:
"Active-Low Interrupt or Square-Wave Output. This open-drain pin requires an external pullup resistor connected to a supply at 5.5V or less. This multifunction pin is determined by the state of the INTCN bit in the Control Register (0Eh). When INTCN is set to logic 0, this pin outputs a square wave and its frequency is determined by RS2 and RS1 bits. When INTCN is set to logic 1, then a match between the timekeeping registers and either of the alarm registers activates the INT/SQW pin (if the alarm is enabled). Because the INTCN bit is set to logic 1 when power is first applied, the pin defaults to an interrupt output with alarms disabled."
Ahhh ok… Thanks??? I’m not too sure what any of that means. I have the rtc successfully connected. In my question I was specifically asking about the code. IE how to set the alarm to go off every 10 min or every hour. (in the code i posted it is set too once a day and I am not sure how to change that) Also where in the sleep code do i put my datalogging sketch? I tried putting it in the void loop below where it clears the alarm but it didn’t work.
Here is what I tried
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
byte AlarmFlag = 0;
byte ledStatus = 1;
#define LOG_INTERVAL  1000 // mills between entries (reduce to take more/faster data)
RTC_DS3231 RTC; // define the Real Time Clock object
// the logging file
File logfile;
  while(1);
void setup(void)
  char filename[] = "LOGGER00.CSV";
  if (! logfile) {
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
#if ECHO_TO_SERIAL
  RTC.clearAlarm(1);
  RTC.clearAlarm(2);
#if ECHO_TO_SERIAL
void loop(void)
    //Set alarm1 20th sec every min
    delay(10000);
    RTC.clearAlarm(1);
    AlarmFlag++;
    ledStatus = 1;
  else {
    ledStatus = 0;
  DateTime now;
#if ECHO_TO_SERIAL
  Serial.print(", ");
#endif
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print('"');
  logfile.print("/");
  logfile.print("/");
  logfile.print(" ");
  logfile.print(":");
  logfile.print(":");
  logfile.print('"');
#if ECHO_TO_SERIAL
  Serial.print(", ");
  Serial.print('"');
  Serial.print("/");
  Serial.print("/");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
  Serial.print('"');
  delay(10);
  logfile.println();
#if ECHO_TO_SERIAL
  Serial.print(", ");
  logfile.flush();
 if (tempReading > 500) {
Ok. I Re-read. I think I understand what you are saying. But I still do not know how to write the code.
You are correct. We misunderstood each other and it’s because I was reading too fast. My fault.
If you are using the library I think you are using, it contains two functions.
void RTC_DS3231::setAlarm(Ds3231_ALARM_TYPES_t alarmType, byte seconds, byte minutes, byte hours, byte daydate)
and
void RTC_DS3231::alarmInterrupt(byte alarmNumber, bool interruptEnabled)
As I understand it, this will not cause an Interrupt every two seconds. Each time the Interrupt is triggered, it will have to be reset for two seconds in the future.
Hello.
For making an alarm each T minutes I put - at the end of setup and at the end of loop:
RTC.setAlarm(ALM1_MATCH_HOURS, 40+cont, 13, 0); //set your wake-up time here. Quando ele chegar em 59, vai dar erro? Vai passar de 60??
Each time he wakes I added this variable "cont" with:
cont++;
something like this:
#include <Wire.h>
byte AlarmFlag = 0;
byte ledStatus = 1;
int cont, segundo =0;
int minuto= 32;
int hora= 14;
  //Set pin D2 as INPUT for accepting the interrupt signal from DS3231/////////
  Wire.begin();
  RTC.begin();
  DateTime a = RTC.now();
  int8_t b=a.hour();
Serial.println("hora");
delay(5); // só consegui printar no serial depois de colocar esse delay, não sei a razão!
  Serial.println(a.hour());
  delay(5);
 Serial.println(a.minute());
 delay(5);
 Serial.print(a.second());
  RTC.clearAlarm(1);
  RTC.clearAlarm(2);
  //Set alarm1 every day at (hora:minuto:segundo)
  RTC.setAlarm(ALM1_MATCH_HOURS, minuto, hora, segundo);   //set your wake-up time here
  if (AlarmFlag == 0) {
    Serial.println("vou dormir");
    Serial.println("To de volta pessoal");
    //When exiting the sleep mode we clear the alarm
    RTC.clearAlarm(1);
    AlarmFlag++;
    cont++;
    ledStatus = 1;
    Serial.println("Acendi");
  else {
    ledStatus = 0;
    Serial.println("Apaguei");
  ///*//Set alarm1 every day at 13:05
  RTC.setAlarm(ALM1_MATCH_HOURS, cont+minuto, hora, segundo);   //set your wake-up time here. Quando ele chegar em 59, vai dar erro? Vai passar de 60??
  AlarmFlag=0;
This is code is a little bit more complete. The arduino wakes every minute and saves a voltage input in A0 on the SD CARD.
// Esse código faz o arduino acordar a cada minuto (aproximadamente) e grava a tensão na porta A0 no cartão SD
//  Ideia: Ao acordar, poderia passar 1 minuto ou 30 segundos gravando informações e depois voltaria a dormir. Que tal?
//  Dessa maneira eu conseguiria pegar um valor médio e mais confiável
#include <Wire.h>
#include <SD.h>
DateTime a;
File myFile;
void printDigits(int digits);
void digitalClockDisplay();
byte AlarmFlag = 0;
byte ledStatus = 1;
int minuto= 19;
int hora= 16;
  Wire.begin();
  RTC.begin();
  //Initialize SD CARD
  // chip is not selected:
  digitalWrite(10, HIGH); // davekw7x: If it's low, the Wiznet chip corrupts the SPI bus
  if (!SD.begin(4))
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  RTC.clearAlarm(1);
  RTC.clearAlarm(2);
    RTC.clearAlarm(1);
    AlarmFlag++;
    cont++;
  uint8_t d = RTC.read(00001111); // Lê o bit7 do STATUS REGISTER(0Fh), que informa
                                  // se a hora foi atualizada recentemente
  if(bitRead(d,7) == 0)
    Serial.println("The time has not been set.  Please run the Time");
    Serial.println("TimeRTCSet example, or DS1307RTC SetTime example.");
    delay(4000);
  myFile = SD.open("Tensoes.txt");
  if(myFile)
    Serial.println("reading Tensoes.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available())
      Serial.write(myFile.read());
    //close the file:
    myFile.close();
  } else
    // if the file didn't open, print an error:
    Serial.println("error opening Tensoes.txt");
  AlarmFlag=0;
void digitalClockDisplay(){
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("Tensoes.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to Tensoes.txt...");
    a=RTC.now();
    // digital clock display of the time
    myFile.print(a.hour());
    printDigits(a.minute());
    printDigits(a.second());
    myFile.print(" ");
    myFile.print(a.day());
    myFile.print(" ");
    myFile.print(a.month());
    myFile.print(" ");
    myFile.print(a.year());
    float a = analogRead(A0);
    myFile.print(" - ");
    myFile.println(a);
    //Inserir fórmula de transformação da tensão!!
    // a= (R2+R1/R2)*a;
    // close the file:
    myFile.close();
    Serial.println("writing done.");
    Serial.println("error opening ola.txt");
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  myFile.print(":");
  if(digits < 10)
    myFile.print('0');
  myFile.print(digits);
