Sleep, interrupt and VirtualWire
My Arduino is put to sleep only to wake up when one of three buttons is pressed.
Only…it doesn’t work.
I receive the “Prêt” message from setup().
Then I connect pin 2 (interrupt 0) to ground: the led on pin 13 lights up but the Arduino doesn’t seem to send anything on pin 12 which is connected to the DATA pin of the RF emitter (my multimeter stays silent whereas it shows a few mA on startup when “Prêt” is sent). The pin never goes off.
#include <avr/sleep.h>
#include <VirtualWire.h>
#include <avr/interrupt.h>  // Do I need that? It was working without it with a previous RF library.
int pinPlaque = 2;
int pinPortes = 3;
int pinAv = 6;
void ouvrePlaque()
  sleep_disable();
  detachInterrupt(0);
  digitalWrite(13, HIGH);  //Debugging
//  vw_set_tx_pin(12);  //Doesn't work wether I place it here or in setup()
//  vw_setup(1000);
  const char *lettre = "lettre";
  vw_send((uint8_t *)lettre, strlen(lettre));
//  digitalWrite(13, LOW);  //Debugging
  vw_wait_tx();
void ouvrePorte()
  sleep_disable();
  detachInterrupt(1);
  const char *av = "avant";
  const char *arr = "arrière";
  if(digitalRead(pinAv) == LOW){
    vw_send((uint8_t *)av, strlen(av));
    vw_wait_tx(); // Wait until the whole message is gone
    vw_send((uint8_t *)arr, strlen(arr));
  vw_set_tx_pin(12);
  vw_setup(1000);      //Vitesse en bps
  pinMode(13, OUTPUT);
  pinMode(pinPlaque, INPUT);
  pinMode(pinPortes, INPUT);
  pinMode(pinAv, INPUT);
  digitalWrite(pinPlaque, HIGH);
  digitalWrite(pinPortes, HIGH);
  digitalWrite(pinAv, HIGH);
  const char *set = "Prêt !";
  vw_send((uint8_t *)set, strlen(set));
  vw_wait_tx();
//  ADCSRA = 0;
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  attachInterrupt(0, ouvrePlaque, FALLING);  // I tried with LOW as well.
  attachInterrupt(1, ouvrePorte, FALLING);
//  MCUCR = bit (BODS) | bit (BODSE);
//  MCUCR = bit (BODS);
  interrupts();
  sleep_cpu();
Is it even possible to use the VirtualWire library inside an ISR?
EDIT: Maybe it isn’t, I got it working that way.
//#include <avr/interrupt.h>  // Do I need that? It was working without it with a previous RF library.
int pinPlaque = 2;
int pinPortes = 3;
int pinAv = 6;
volatile int int_flag = 0;
const char *lettre = "Lettre";
const char *av = "Colis";
const char *arr = "Relève";
void ouvrePlaque()
  int_flag = 1;
void ouvrePorte()
    int_flag = 2;
    int_flag = 3;
  vw_set_tx_pin(12);  //Pin d'émission
  pinMode(pinPlaque, INPUT_PULLUP);
  pinMode(pinPortes, INPUT_PULLUP);
  pinMode(pinAv, INPUT_PULLUP);
  vw_wait_tx();
  ADCSRA = 0;
  if(int_flag==1)
    detachInterrupt(0);
    vw_send((uint8_t *)lettre, strlen(lettre));  //Sending via RF
    vw_wait_tx();  //Waiting for message to be sent
  else if(int_flag==2)
    detachInterrupt(1);
  else if(int_flag==3)
    detachInterrupt(1);
  int_flag=0;
  sleep_enable();
  MCUCR = bit (BODS);
  interrupts();
  sleep_cpu();
If an optimization/sleep guru could take a look at my code, I would really appreciate it :slight_smile:
