sleep mode while using millis
Hello Is there any way to get into sleep mode while still running the clock to keep the millis running?
Check this page with all about power saving modes, the answer might be in there
In IDLE mode, the clocks are running. This means that (unless you disable it) the normal Timer 0 clock used to count millis() will be running, and thus you will wake up approximately every millisecond.
