Hello I am new to programming I recently started a project and I need some help with a control feature I want to add and having an issue.
What I want to achieve is the control style of a mobile power button.
When power button is hold down device goes to sleep or wake if it is already in sleep mode.
Also one single button click have another function. But so far, once I put it into sleep, I cannot wake it up, only by resetting.
This is my try so far.
#include <avr/sleep.h>
#include <avr/interrupt.h>
#include <Bounce2.h>
int controlButton = 2; // button
int pwr1 = 10; // 7 segment display common kathode
int pwr2 = 11; // 7 segment display common kathode
int pwr3 = 12; // 7 segment display common kathode
int pwr4 = 13; // 7 led user interface common kathode
int ledHeat = A2; // PID output
int lastButtonStateControl;
int currentButtonStateControl;
unsigned long pwrDnTime; // to keep track of hold down time
boolean Control = 0; // this is the var that changes in simple click
Bounce debouncerControl = Bounce();
#define holdTime 3000
void setup ()
digitalWrite(controlButton , HIGH);
debouncerControl.attach(controlButton);
debouncerControl.interval(5);
void sleepNow()
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
attachInterrupt (0, wakeUpNow, CHANGE);
digitalWrite (pwr1, LOW);
digitalWrite (pwr2, LOW);
digitalWrite (pwr3, LOW);
digitalWrite (pwr4, LOW);
digitalWrite (ledHeat, LOW);
sleep_mode();
sleep_cpu();
void wakeUpNow()
sleep_disable();
detachInterrupt(0);
currentButtonStateControl = debouncerControl.read(); // debounce library analog read
if (currentButtonStateControl == HIGH && lastButtonStateControl == LOW)
pwrDnTime = millis();
if (currentButtonStateControl == LOW && lastButtonStateControl == HIGH)
Control = !(Control);
if (currentButtonStateControl == HIGH && (millis() - pwrDnTime) > holdTime)
sleepNow();
lastButtonStateControl = currentButtonStateControl;
Thank you for your fast reply. I made the changes you told me. And yes I have read the interrupt s and sleep examples and reference. I also watched some videos about interrupt and google it. But still can’t figure what I am doing wrong. I can make it sleep (I think) at least the segment is turned off.
Specifically, I refer you to Table 10-1 on page 38 in teh Power Management and Sleep Modes section. Look at that table, specifically the Wake Up Sorces part, and see if you can figure out why your procssor won't wake up.
I did read the power management it says I can wake up from (SLEEP_MODE_PWR_DOWN) with pin change INT1, INT0. TWI Address Match & Watchdog Timer.
From Datasheet “An external level interrupt on INT0 or INT1, or a pin change interrupt can wake up the MCU”
INT0 is D2 Pin at least that’s what I understood, and that’s where I have connected the button.
So I guess I will have to disable TWI Address Match & Watchdog Timer for more power efficiency since I only need pin change. On the other hand I need this to wake up on button hold. So I will need Watchdog Timer enable?
Ok now I think I start to understand. However in attachInterrupt(0, wakeUpNow, LOW); when it turns off after 3 sec and I take my finger from the button it wakes up again.
So i will have to make it wake up on single click and "look like it is off (digital/analogWrite LOW)".
If the button is held down for less than 3 sec then it will go to sleep again and if button is held down for more than 3 sec will wake.
