Sleepy Pi bricked after uploading sketch
Hi
I have a sleepy pi (arduino board hat for raspberry pi - one of these Sleepy Pi 2 - Micro USB B - Spell Foundry )
I uploaded the example alarm clock sketch from their github repository (after running the pi setup script to get the two to handshake).
After doing it, when I powered it all down, the sleepy pi board won’t power up. Can’t talk to it, can’t get it to do anything. Its completely bricked. (No, it doesn’t wake the Pi when it is meant to when I leave it).
Thinking I’d done something wrong, I bought another. Uploaded the same sketch, and the same thing happened. Bricked and dead.
Does anyone have any experience of these boards, or suggestions as to what I may have done wrong?
Their example code is here. I had to make a small change and change Time.h to TimeLib.h but anyway…
// Simple example showing how to set the RTC alarm pin to wake up the Arduino.
// This is a different mode to the alarm clock, which wakes at a particular time.
// This mode is a repeating periodic time, waking the Arduino at fixed intervals.
// Note: this example doesn't wake up the RPi. For that add:
//     SleepyPi.enablePiPower(true);
// after arduino wakeup. For a clearer picture of how to do this see the
// eaxmple WakePiPeriodically which wakes the Rpi at fixed intervals.
// To test on the RPi without power cycling and using the Arduino IDE
// to view the debug messages, either fit the Power Jumper or enable
// self-power. http://spellfoundry.com/sleepy-pi/programming-arduino-ide/
// **** INCLUDES *****
#include "SleepyPi2.h"
#include <Time.h>
#include <LowPower.h>
#include <PCF8523.h>
#include <Wire.h>
const char *monthName[12] = {
  "Jan", "Feb", "Mar", "Apr", "May", "Jun",
  "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
const int LED_PIN = 13;
// Globals
// ++++++++++++++++++++ Change me ++++++++++++++++++
// .. Setup the Periodic Timer
// .. use either eTB_SECOND or eTB_MINUTE or eTB_HOUR
eTIMER_TIMEBASE  PeriodicTimer_Timebase     = eTB_SECOND;   // e.g. Timebase set to seconds. Other options: eTB_MINUTE, eTB_HOUR
uint8_t          PeriodicTimer_Value        = 10;           // Timer Interval in units of Timebase e.g 10 seconds
// ++++++++++++++++++++ End Change me ++++++++++++++++++
tmElements_t tm;
void alarm_isr()
    // Just a handler for the alarm interrupt.
    // You could do something here
  // Configure "Standard" LED pin
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN,LOW);		// Switch off LED
  // initialize serial communication: In Arduino IDE use "Serial Monitor"
  Serial.println("Starting, but I'm going to go to sleep for a while...");
  delay(50);
  SleepyPi.rtcInit(true);
  // Default the clock to the time this was compiled.
  // Comment out if the clock is set by other means
  // ...get the date and time the compiler was run
  if (getDate(__DATE__) && getTime(__TIME__)) {
      // and configure the RTC with this info
      SleepyPi.setTime(DateTime(F(__DATE__), F(__TIME__)));
  printTimeNow();
  Serial.print("Periodic Interval Set for: ");
  Serial.print(PeriodicTimer_Value);
  switch(PeriodicTimer_Timebase)
    case eTB_SECOND:
      Serial.println(" seconds");
    case eTB_MINUTE:
      Serial.println(" minutes");
    case eTB_HOUR:
      Serial.println(" hours");
    default:
        Serial.println(" unknown timebase");
    SleepyPi.rtcClearInterrupts();
    // Allow wake up alarm to trigger interrupt on falling edge.
    attachInterrupt(0, alarm_isr, FALLING);    // Alarm pin
    // Set the Periodic Timer
    SleepyPi.setTimer1(PeriodicTimer_Timebase, PeriodicTimer_Value);
    // Enter power down state with ADC and BOD module disabled.
    // Wake up when wake up pin is low.
    SleepyPi.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
    // Disable external pin interrupt on wake up pin.
    detachInterrupt(0);
    SleepyPi.ackTimer1();
    // Do something here
    // Example: Read sensor, data logging, data transmission.
    // Just a handler for the pin interrupt.
    digitalWrite(LED_PIN,HIGH);    // Switch on LED
    Serial.println("I've Just woken up on a Periodic Timer!");
    // Print the time
    printTimeNow();
    delay(50);
//  - Helper routines
void printTimeNow()
    // Read the time
    DateTime now = SleepyPi.readTime();
    // Print out the time
    Serial.print("Ok, Time = ");
    print2digits(now.hour());
    Serial.write(':');
    print2digits(now.minute());
    Serial.write(':');
    print2digits(now.second());
    Serial.print(", Date (D/M/Y) = ");
    Serial.print(now.day());
    Serial.write('/');
    Serial.print(now.month());
    Serial.write('/');
    Serial.print(now.year(), DEC);
    return;
bool getTime(const char *str)
  int Hour, Min, Sec;
  if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
  tm.Hour = Hour;
  tm.Minute = Min;
  tm.Second = Sec;
  return true;
bool getDate(const char *str)
  char Month[12];
  int Day, Year;
  uint8_t monthIndex;
  if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
  for (monthIndex = 0; monthIndex < 12; monthIndex++) {
    if (strcmp(Month, monthName[monthIndex]) == 0) break;
  if (monthIndex >= 12) return false;
  tm.Day = Day;
  tm.Month = monthIndex + 1;
  tm.Year = CalendarYrToTm(Year);
  return true;
void print2digits(int number) {
  if (number >= 0 && number < 10) {
    Serial.write('0');
  Serial.print(number);
Can you upload to the "bricked" sleepy pi?
Does the Raspberry Pi still work normally when the sleepy pi is removed?
Yeah the pi works normally.
I can't upload to the sleepy because it won't power up. The sleepy is supposed to power the pi when connected, but it doesn't do this either. Press power, nothing happens. You can program it as a standalone board with a pc, but again to do this it needs to power up.
No response from the makers (spellfoundry) about this issue.
Disappointing. I'd suggest avoiding this product.
Spellfoundry got back in touch. Sadly their suggestions did not work. It would appear that I have two dead boards, and £70 down the drain. Oh well, you live & learn.
