My project is to make a slider, the trolley is controlled by a Nema23 motor including an incremental encoder, and the turntable is controlled by a Nema 17 … I have two inductive limit switches at the ends of the line, and an inductive limit switch on the turntable …
When I download the code of the encoder and I move the cart with my hand it works well and I get the information of the encoder in translation
I have fixed everything but my problem is that:
The engine works fine, but when I insert the encoder code into the program, the engine stops and does not move forward.
and I do not know how to do a function to tell him to move forward and return to zero point!
this is my code :
//pins direction et nbre de pas
int PULNema23 = 40;
int DIRNema23 = 39;
int PULNema17 = 38;
int DIRNema17 = 37;
// Nbre de pas (1tour=6400pas=6,7cm pour la translation)
int stepsAvance = 6400; // il faut les paramétrer après
int stepsRecule = 6400;
int stepsRot = 24000;
int pinBouton = 6;//pin en entrée pour le bouton poussoir
const int interruptNema23A = 0;//numéro de l’interruption 0, correspond au pin 2
const int interruptNema23B = 1;//numéro de l’interruption 1, correspond au pin 3
const int interruptGauche = 2;//numéro de l’interruption 2, correspond au pin 18
const int interruptDroite = 3;//numéro de l’interruption 3, correspond au pin 19
const int interruptCentre = 4;//numéro de l’interruption 4, correspond au pin 20
//variables pour les fonction interrupt ::Sur un Arduino Mega, les numéros 0 à 5 correspondent aux broches 21,20,19,18,2et3//
const int pinInterruptNema23A = 2;
const int pinInterruptNema23B = 3;
const int pinInterruptGauche = 21;
const int pinInterruptDroite = 20;
const int pinInterruptCentre = 19;
//variables pour la fonction encodeur//
float encoNema23 = 0;
float newVal = 0;
float distanceNema23 = 0;
pinMode (PULNema23, OUTPUT);
pinMode (DIRNema23, OUTPUT);
pinMode (PULNema17, OUTPUT);
pinMode (DIRNema17, OUTPUT);
pinMode(pinBouton, INPUT_PULLUP);//pin 6 du bouton en mode INPUT_PULLUP
pinMode(pinInterruptNema23A, INPUT);
pinMode(pinInterruptNema23B, INPUT);
pinMode(pinInterruptGauche, INPUT);
pinMode(pinInterruptDroite, INPUT);
pinMode(pinInterruptCentre, INPUT);
//les interruptions :
attachInterrupt(interruptNema23A, ISRNema23A, RISING);//déclenchement de l’interruption pour l’execution de la fonction ISRNema17 quand la broche concernée passe de LOW à HIGH
attachInterrupt(interruptNema23B, ISRNema23B, RISING);//déclenchement de l’interruption pour l’execution de la fonction ISRNema23 quand la broche concernée passe de LOW à HIGH
attachInterrupt(interruptGauche, ISRGauche, RISING);//déclenchement de l’interruption pour l’execution de la fonction ISRGauche quand la broche concernée change d’état, c’est à dire passe de LOW à HIGH ou bien de HIGH à LOW
attachInterrupt(interruptDroite, ISRDroite, RISING);//déclenchement de l’interruption pour l’execution de la fonction ISRDroite quand la broche concernée change d’état, c’est à dire passe de LOW à HIGH ou bien de HIGH à LOW
attachInterrupt(interruptCentre, ISRCentre, RISING);//déclenchement de l’interruption pour l’execution de la fonction ISRCentre quand la broche concernée change d’état, c’est à dire passe de LOW à HIGH ou bien de HIGH à LOW
//Serial.begin(9600);
//Serial.println(“Démarrage du programme”);
/* boolean etatBouton = digitalRead(pinBouton); //test de l’état du bouton avec boolean etatBouton
if (etatBouton == 0)//test si bouton appuyé et relach*/
avance();
stopNema23();
rotation();
stopNema17();
recule();
void count()
if (encoNema23 != newVal)
Serial.print("Nombre d’impulsions = ");
Serial.println(encoNema23);
Serial.print("Distance parcourue en cm = ");
Serial.println(distanceNema23);
newVal = encoNema23;
// fonction pour reculer le chariot (Nema23)
void recule()
for (int i = 0; i < stepsRecule; i++)
digitalWrite(DIRNema23, LOW);
digitalWrite(PULNema23, HIGH);
delayMicroseconds(50);
digitalWrite(PULNema23, LOW);
// fonction pour avancer le chariot (Nema23)
void avance() {
for (int i = 0; i < stepsAvance; i++)
digitalWrite(DIRNema23, HIGH);
// fonction pour la rotation du chariot (Nema17)
void rotation()
for (int i = 0; i < stepsRot; i++) //rotation de 360°
digitalWrite(DIRNema17, LOW);
digitalWrite(PULNema17, HIGH);
digitalWrite(PULNema17, LOW);
//fonction pour arreter le chariot
void stopNema23()
arreter la translation
//fonction pour arreter la table tournante de tourner
void stopNema17()
arreter la rotation
//fonction servant à remettre à zéro les variables des encodeurs
void remiseAZeroEncodeur()
distanceNema23 = 0;
encoNema23 = 0;
//Fonction d’interruption pour le codeur Nema23A
void ISRNema23A()
if (digitalRead(3) == HIGH) {
encoNema23++;
encoNema23–;
distanceNema23 = distanceparcourue(encoNema23);
void ISRNema23B()
if (digitalRead(2) == HIGH) {
encoNema23–;
encoNema23++;
//Fonction convertisseur impulsions en distance(cm)
float distanceparcourue(float impulsions)
float a = ((6.7)/1000) * impulsions;
return a;
//Fonction convertisseur distance(cm) en impulsions
float impulsionsparcourues(float distance)
float a = (distance *1000 /(6.7));
return a;
//fonction d’interruption ou la routine d’interruption après la detection du capteur inductif de fin de course gauche
void ISRGauche()
stopNema23();
remiseAZeroEncodeur();
//Recommencer le loop à zéro
//fonction d’interruption ou la routine d’interruption après la detection du capteur inductif de fin de course droite
void ISRDroite()
stopNema23();
//Revenir au point zéro
//fonction d’interruption ou la routine d’interruption après la detection du capteur inductif de fin de course au milieu dans la table tournante
void ISRCentre()
stopNema17();
