Hi all, I cobbled together a 328p on strip board, wired a lcd display and connected some DHT22's up (in/out) earlier in the year.
Works nicely, but the weather has just dipped here and dropping below freezing. I'm noticing my LCD is telling me it is -0 ouside -1 yes but -0? is there such a thing? I would like to get rid of the - symbol ideally?
//parameters
const int minLight = 40; // at or below this light level, use minimum backlight intensity
const int maxLight = 900; // at or above this light level, use maximum backlight intensity
const int minBacklight = 30; // lowest backlight intensity to use
const int maxBacklight = 255; // highest backlight intensity to use
const int LDRPin = A1; // Analog input pin that the lDR is attached to
const int LCDBackLight = 3; // Analog (PWM) output pin that the BACKLIGHT is attached to
int LDRRead = 0; // value read from the LDR
int outputValue = 0; // value output to the PWM (analog out)
// make some custom characters:
byte rh[8] = {
0b00101,
0b00111,
0b10101,
0b01000,
0b00100,
0b11010,
0b10001,
0b10000
byte degree[8] = {
0b00111,
0b00101,
0b00111,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000
byte c[8] = {
0b00000,
0b00000,
0b00000,
0b11100,
0b10000,
0b10000,
0b10000,
0b11100
#include "DHT.h"
#include <LiquidCrystal.h>
#define DHTAPIN 5 // what pin we're connected to in
#define DHTBPIN 6 // what pin we're connected to out
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht_in(DHTAPIN, DHTTYPE);
DHT dht_out(DHTBPIN, DHTTYPE);
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
lcd.begin(16, 2);
delay(100);
dht_in.begin();
dht_out.begin();
pinMode(3, OUTPUT); //LCD BACKLIGHT
// create new characters
lcd.createChar(0, rh);
lcd.createChar(1, degree);
lcd.createChar(2, c);
// LDR controlled LCD backlight via PWM part
int sum = 0;
for (int i=0; i<16; i++) // take 16 samples from the analog input
sum += analogRead(LDRPin);
LDRRead = sum/16; // divide by the amount of samples for the average value
// map it to the range[0..255] of the analog output that the LCD backlight it connected to
outputValue = LDRRead/4; // alternative to map function for scaling down from analog input
outputValue = map(constrain(LDRRead, minLight, maxLight), minLight, maxLight, minBacklight, maxBacklight );
// change the analog out value to adjust LCD backlight intensity
analogWrite(LCDBackLight, outputValue);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h_in = dht_in.readHumidity();
float t_in = dht_in.readTemperature();
float h_out = dht_out.readHumidity();
float t_out = dht_out.readTemperature();
//Inside readings
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t_in) || isnan(h_in)) {
lcd.setCursor(0, 0);
lcd.print(" No connection ");
else {
//write temp data
lcd.print("In : ");
lcd.print(t_in, 0);
lcd.write((uint8_t)1);
lcd.write((uint8_t)2);
lcd.print(" ");
//write humidity data
lcd.print(h_in, 0);
lcd.print("% ");
lcd.write((uint8_t)0);
lcd.print(" ");
//Outside readings
if (isnan(t_out) || isnan(h_out)) {
lcd.setCursor(0, 1);
else {
//write temp data
lcd.print("Out: ");
lcd.print(t_out, 0);
lcd.print(" ");
lcd.print(h_out, 0);
lcd.print("% ");
lcd.print(" ");
