Slight change in my user name....
I thought "inokashira" was appropriate because it has "ino" in it.
Inokashira is a park in Tokyo, but it can also be understood (in Japanese, with a little stretch) as "Sounds good, probably".
The slight change would simply to change "inokashira" to "kashira.ino" to make it more Arduinish...
Thanks!
User name changes can be problematic.
More common method is to create a new account altogether.
Be aware that the old account should be REPORT TO MODERATROR and no longer in use so they can BAN it or DELETE it. That will prevent the new account from becoming seen as a SOCK PUPPET.
Also be aware that new accounts may take up to 7 days to become fully active if you use the same email.
