slight update to pulseIn() function documentation
I found this in the source code for pulseIn():
"/* Measures the length (in microseconds) of a pulse on the pin; state is HIGH
  • or LOW, the type of pulse to measure. Works on pulses from 2-3 microseconds
  • to 3 minutes in length, but must be called at least a few dozen microseconds
  • before the start of the pulse. */"
However, this is not in the documentation here: http://arduino.cc/en/Reference/PulseIn
Please update the documentation to contain the above information, which is critical for certain applications. The line I especially found useful from the source code is that the function **“must be called at least a few dozen microseconds before the start of the pulse.” **
For your question, please create a new topic under Project Guidance then edit your post above and remove the question.
[quote author=Coding Badly link=topic=196556.msg1450667#msg1450667 date=1383293370]
[/quote]
Done. My new thread and my project question is located here: http://forum.arduino.cc//index.php?topic=196592.0
Thank you.
Do you think my suggestion will actually get added to the Arduino reference page for pulseIn?
I don't know.
