Slightly burnt temperature sensor. Should I throw it away?
I've been messing with the TMP36 temperature sensor. I wired it wrong and connected Vin to GND and viceversa. :cold_sweat:
Ok, before you ask how has this happened, let me explain: this happened because, instead of connecting it as in the book's picture, I decided to read the datasheet to make sure. Turns out that whoever did this document is an optical illusions enthusiast. From the datasheet:
My package was the third one, I just saw PIN1=Vs, PIN2=Vout, PIN3=GND without noticing that, unlike the other two packages, the sensor is depicted from below.
So I wired Vs to GND and GND to +5V by mistake. It smelled like something was burning, so I switched the circuit off. After re-reading specs to double-check the input voltage range [2.7V, 5.5V], tried again, even tried with 3.3 V, again with 5V plus series resistors, etc. In this case, it didn't burn because the voltage was about -1V in the sensor. In the end I connected it again to raw -5V, toasted it for a few seconds before I switched the whole thing off.
Finally I connected it the correct way. Looks like the readings are ok for room temperature. I'm no expert, but my gut tells me I should just trash it. My question is, this thing is made of a few transistors and resistors (page 8 of the datasheet, linked above). Do they actually get damaged when connected to negative voltages?
I'd not use it in any final circuit. It smells burnt, it clearly got hot enough inside to damage the plastic packaging. You don't even get that from soldering.
I agree. You may be able to pull it off in prototyping on a breadboard or something to that nature, but you need to get a new sensor, just to be on the safe side
Roger that.
