Hey still learning the ropes of arduino so thought i'd see what you guys had to say. This is my second little build. I've been fiddling with some minor things which Helped me learn some stuff so i was able to build this.
It is a mini music making board (possibly make something to go in a box at some point but with more controls)
I'm using a little peizo speaker and two potentiometers. One potentiometer controls speed, while the other controls pitch. Originally i just had the one which controlled pitch. But dug out a second one for speed control.
Next up POV display methinks. Should be fun XD
Video:
Code:
/*Basic Synth
*by CaptainCool
*Super Basic music maker
int potPin = 2; // select the input pin for the potentiometer
int potPin2 = 3; // select the input pin for the 2nd potentiometer
int speakPin = 9; // select the pin for the speaker
int val = 0; // variable to store the value coming from the potentiometer1
int val2= 0; // variable to store the value coming from the potentiometer the 2nd
pinMode(speakPin, OUTPUT); // declare the speakPin as an OUTPUT
val = analogRead(potPin); // read the value from the potentiometer
val2 = analogRead(potPin2); // read the value from the second potentiometer
tone (speakPin, val, val2); // make a tone of pitch val and length val 2
int pauseBetweenNotes = val2 * 1.30; //takes val2 and multiplies it by 1.3
delay(pauseBetweenNotes); // which gives you a nice delay between notes so they don't just blend
All feedback is welcome
