Hi Everyone I wonder if anyone can help on this one.
What this does:
A rotary encoder counter determines the speed of a stepper motor. Every completed loop LoopCounter++. When LoopCounter reaches the number determined by the Encoder Counter (counter) the stepper makes a step. Then LoopCounter=0
My problem:
The rotary "slips"unless I turn the knob sloooowly and in a controlled manner over the clicking of the encoder. As if it would need time between the first and second sensor. Is the loop too long?
By slipping I mean that it goes one up and one down instead of just one up.
Also, the speed control won't work if I omit the line
Serial.println(LoopCounter);
Any clue why that is? (I'm expecting a RTFM here)
Thanks in advance!
This is the full code:
// LOOP counter
int LoopCounter =0;
// variables for the rotary encoder
int outputA = 3;
int outputB = 2;
// Starting from 100 because of issue with decreasing and increasing
//TODO: see if it is mechanical problem, try with a different rotary
unsigned int counter = 1;
//current state
int aState;
int aLastState;
// new bits to control speed in real time ++
int lastChange; // the time of changing pin state
int state = HIGH;
const int buttonPin = 12; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int ledState = 0; // remember current led state
//declare variables for the motor pins
int motorPin1 = 8; // Arduino pin 8 to In 1 on the ULN2003
int motorPin2 = 9; // Arduino pin 9 to In 2 on the ULN2003
int motorPin3 = 10; // Arduino pin 10 to In 3 on the ULN2003
int motorPin4 = 11; // Arduino pin 11 to In 4 on the ULN2003
// supply power to + and - from Arduino 5vdc and gnd
int motorSpeed = 1250; // set speed of 28BYJ-48 stepper,
//max frequency is 100hz, so max speed is 1250
int lookup[8] = {B01001, B00001, B00011, B00010, B00110,B00100,B01100, B01000};
// pins for the encoder
pinMode (outputA,INPUT);
pinMode (outputB,INPUT);
// Reads the initial state of the outputA
aLastState = digitalRead(outputA);
lastChange = millis(); // ledpin state changed NOW
digitalWrite(ledPin, state);
pinMode(buttonPin, INPUT_PULLUP); // initialize the button pin as a input
pinMode(ledPin, OUTPUT); // initialize the button pin as a output
//declare the motor pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
// Number of loops since the last step increases of one unit
LoopCounter++;
// if the counter is above 5000 it goes back to 0 to avoid
if (counter >= 5000)
counter = 0 ;
aState = digitalRead(outputA); // Reads the "current" state of the outputA
// If the previous and the current state of the outputA are different, that means a Pulse has occured
if (aState != aLastState){
// If the outputB state is different to the outputA state, that means the encoder is rotating clockwise
if (digitalRead(outputB) != aState) {
counter ++;
counter --;
if (counter>=400){
counter==0;}
Serial.print("Position: ");
Serial.println(counter);
aLastState = aState; // Updates the previous state of the outputA with the current state
if (counter >= 400){
counter == 0;}
//this IF determines delay time between one step and the next one
if (LoopCounter >= counter){
LoopCounter=0;
// invert led's state
state = !state;
// read the pushbutton input pin, did we reach the edge?
buttonState = digitalRead(buttonPin);
// by comparing the buttonState to its previous state
if (buttonState != lastButtonState) {
// change the state of the led when someone pressed the button
if (buttonState == 1) {
if(ledState==1) ledState=0;
else ledState=1;
// remember the current state of the button
lastButtonState = buttonState;
// turns LED on if the ledState=1 or off if the ledState=0
if(ledState == 0 && buttonState == LOW)
clockwise();
else if(ledState == 1 && buttonState == LOW)
anticlockwise();
else if (ledState == 1 && buttonState == HIGH)
clockwise();
else if(ledState == 0 && buttonState == HIGH)
anticlockwise();
void clockwise()
for(int i = 0; i < 8; i++) // 8 pulses
setOutput(i);
delayMicroseconds(motorSpeed);
void anticlockwise()
for(int i = 7; i >= 0; i--) // 8 pulses
setOutput(i);
void setOutput(int out)
digitalWrite(motorPin1, bitRead(lookup[out], 0));
digitalWrite(motorPin2, bitRead(lookup[out], 1));
digitalWrite(motorPin3, bitRead(lookup[out], 2));
digitalWrite(motorPin4, bitRead(lookup[out], 3));
