Hello everyone,
I am a mechanical engineering student working on a project and I have come across a few problems.
My hardware currently consists of an Arduino Uno R3 with an Arduino WiFi Shield and a wireless router.
To give a summary, I have designed an HTML/JavaScript website with one button that will turn on/off the built-in LED via an AJAX get request. The button has been designed so that when I perform a "mousedown," the LED turns on. Similarly, "mouseup" will turn the LED off.
#include <SPI.h>
#include <WiFi.h>
IPAddress ip(192,168,0,200); // Set a static IP
int status = WL_IDLE_STATUS;
WiFiServer server(80);
boolean isReading = false;
WiFi.config(ip);
pinMode(9, OUTPUT);
} // end setup()
WiFiClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read bytes from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: keep-alive");
client.println();
client.println("<!DOCTYPE html>");
client.println("<html><head>");
client.println("<script>");
client.println("function GetLed(c){");
client.println("var request = new XMLHttpRequest();");
client.println("request.open(\"GET\", \"?action=\" +c);");
client.println("request.send();}");
client.println("</script></head><body>");
client.println("<h1>Attempt at speed</h1>");
client.println("<button id=\"led\" type=\"button\">LED</button>");
client.println("led.addEventListener(\"mousedown\",function(){GetLed(1);});");
client.println("led.addEventListener(\"mouseup\",function(){GetLed(0);});");
client.println("</script></body></html>");
client.println("");
} // End client.println stuffs
if (c == ' ') isReading = false;
if (c == '?') isReading = true;
if (isReading){
if (c == '1') {
digitalWrite(9,HIGH);
if (c == '0') {
digitalWrite(9,LOW);
// every line of text received from the client ends with \r or \n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
// delay(50); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
} // end void
The LED turns on and off instantly once the left mouse button is held or released (as expected); HOWEVER, there is an approximate 2 second delay before I can use the button again, else the system will hang or lag.
I previously had the serial monitor open, which would display all of the HTTP requests. Like I said, I wasn't able to execute another command until the get request went through and was displayed completely on the serial monitor (which makes sense), but I do not understand why it is taking so long.
Programming isn't really something that is stressed in my curriculum, so I would appreciate any help.
Is there something wrong with the way I have structured my code (particularly in the void loop section), or is it a hardware issue?
Thank you in advance.
In the future, I will be implementing servos and multiple buttons to control them.
