Slow encoder response
Hello,
I read the analog input and compare it to a value that I want. I also use hysteresis and delay to run two pwm controlled motors. When I run the program below, everything works fine if I turn the encoder slowly, any value is left in any of its output when I turn the encoder a little fast. Is the logic in the program completely wrong?
test_9_2_wo_led_4.txt (7.39 KB)
I didn't look deeply but there are quite a few of these:
      coldout == 0;
Try setting IDE->file/preferences/compiler warnings to All.
Whoops - dangling elses everywhere - very confusing and definitely bad style:
This is a dangling-else:
if (cond1)
  if (cond2)
    foo();
    bar();
Which if is the else meant to correspond to?
What if I wrote it:
if (cond1)
  if (cond2)
    foo();
  bar();
The compiler sees these the same, whereas a human might see them different.
So always use braces when nesting if-elses:
if (cond1)
  if (cond2)
    foo();
  bar();
or
if (cond1)
  if (cond2)
    foo();
    bar();
Then the intention is unambiguous. Remember that the indentation is completely
ignored by the language & compiler in C.
In fact there's an argument to always use braces for the then and else parts of a
conditional statement, although this is perhaps overkill.
BTW your encoder code is way over-complex, encoders do not need and shouldn't be
given debouncing logic, as they self-correct due to the nature of quadrature signals.
