I looking for a solution to slower get from a function to a other.
1st here my code :
vin = analogRead(A2);
Calculate_Vout();
OCR1A = vout/2; // Output on PA6 with (it output vout/2 but cause vin is in 10 bit and output in 9bit).
void Calculate_Vout() {
if ((vin > 0) && (vin < 246)) vout = vin/2;
else if ((vin > 246) && (vin < 500)) vout = vin/3;
else if ((vin > 500) && (vin < 800)) vout = vin/4;
else vout = vin;
1st the code read the voltage on A2 (vin = analogRead(A2) then we calculate vout in void Calculate_Vout(), that were i looking for way to jump slowly from one if to a other else if... because when we switch from one to a other, the output voltage did a fast jump that cause me trouble.
Is there any function that can do that ?
The last line seems to be a typo.
Consider that vin is something about 800...
If vin = 799 so the expression vin/4 will be used and result will be 199
but if we increase the vin just on 2 units - to 801 - in this case the last line of function give as vout = vin;, so result will be 801 - a four times more!
If we do not pay attention to this obvious mistake, then in order for there to be no jumps between the ranges, you need either more steps, for example, not only vout/2, vout/3 and vout/4, but also intermediate vout/1.5, vout/2.5 etc...
Or choose a continuous function. However, this is not a best solution always, because with the function the program will be larger and run slower.
You right, but all this value is just for sample to illustrate, i real use there is more complex formula and 7 step at this point from 0 to 1023, i just use this sample to have a clear look.
Of course there is possibility to add more else if between, but that will make a lot.
I did not use it, but what could be difficult there? Did you try the examples, if any?
You not even need the library, use a simple linear interpolation between two points, this is taught in school...
If the relationship between vin and vout is completely linear, you could simply use map (retaining your original, not very pretty, program structure) - untested :
uint16_t vin ;
uint16_t vout ;
Calculate_Vout();
vout = map( vin, 0, 1023, 0, 255 ) ;
If it is not completely linear, then say what the formula should be or supply a mapping table, or hand draw a graph.
1st, thanks for help.
It is linear, but look, i add the comment in the code here to show what i need :
>>> Here is where i need a smooth linear transition from the previous line to the next one <<<
else vout = vin;
Making coeff larger (up to 1.0) will make the transition faster. At coeff = 1.0, no filtering takes place. Making coeff smaller will make the transition slower, and smoother. Typical values for coeff will generally be in the range of 0.01 to 0.1.
There are several solutions and it described above. But look to your data.
I wrote to you that your steps are wrong - but you do not pay attention.
At first, with each step, the slope decreases, and then sharply increases on the last step. It is difficult to make smooth transitions on such data. You seem to have mixed up the ratios
...you didn't understand.... It's not about specific data.
In order to smooth your formulas, they must converge at common points. But your data is not like that. When you shift by one point, the value changes several times. There is no point in smoothing such data, your formulas are simply wrong.
That is why you failed to apply the interpolation to them.
To use interpolation, you must specify points, not these formulas. For example
Oh ok, i see now what you mean, sorry.
But that will not be possible (or at this point i don't know how), because my final formula use a variable, here the 2 first of the final formulas :
