Whan i prees the "get data from dht11" button in my app via bluetooth - is take aprox 4-6 sec to load the data from the dht11 sensor.
What can i do to improve the load time of the dht11 via bluetooth?
all the ohter parts work fine...
else if (state == 't'){
int t = (int)dht.readTemperature();
Serial.println(String(t) + ".0°c" + " - " + (h) + "%");
Thanks
A.S
system
2
Cross-post deleted.
What app?
Post your code.
system
3
The dht.readTemperature() call will take some amount of time, unless you use the non-blocking process described in the source code.
Of course, if you do that, you would not be calling the function because you got a 't'. You would be sending the latest reading when you got a 't'.
