Slow opening ino files. Typed characters get into a *.ino file.
When my project has twenty *.ino files with some of 1000 lines per file, then they open slow. Meanwhile, I can do other things (so I thought), but what I type will get into a *.ino file.
Ubuntu linux, Arduino IDE 2.0.0-beta.3
I opened a project for the first time. The board was not set. I opened the drop-down in the bar for "Select Other Board & Port", then I searched for "uno". However, the tabs with *.ino files were still filling and the typed text was stored in a *.ino file.
This slow opening happened just once. Even after restarting my computer, loading the *.ino files is still many times faster.
Because the compiler gave an error, I could find the text that got into a *.ino file.
The dot in the tab label (after the file name) disappears so fast, that does not help to find a changed *.ino file.
Koepel:
Hi @Koepel. Thanks for the feedback! I monitor the Arduino IDE 2.x repository's tracker closely and I don't remember a report for this, so you're welcome to submit an issue to bring this to the attention of the developers:
Koepel:
Arduino IDE 2.x has a File > Preferences > Auto save setting that is on by default. This is similar to the classic Arduino IDE's File > Preferences > Save when verifying or uploading, except it saves every 500 ms (configurable via the advanced settings).
So if you don't like this behavior of saving changes near-instantly, you can disable it in the preferences. You can also configure the auto save delay in the advanced IDE settings accessible via the gear icon on the bottom left corner.
