Slow response time between C# and mega2526
I'm certain that I'm in the wrong forum.
My question is. Is there any way to increase the response time between a C# program to the Arduino and vice versa?
If in fact, this is the wrong forum could someone send a link to the proper forum?
Many thanks in advance. PS I'm somewhat of a newbie.
Ken
What sort of change are we talking about here?
You need to hang numbers and units on this sort of question
I don't understand your question.
How are the 2 systems communicating ?
If it is a serial link then does the C# program keep the serial link open or does it open and close it as part of the communication protocol ?
It stays open.
if(Serial.available()){
data = Serial.readString();
A very simple way to increase the response time is to add a massive delay.
How would adding a delay increase the response time between reading and writing?
I have this delay:
s1. write(servoval);
delay(10); // wait for servo to finish
You are using Serial.readString();
From Serial.readString() - Arduino Reference
Serial.readString() reads characters from the serial buffer into a String. The function terminates if it times out (see setTimeout()).
What is the timeout set to ?
By increasing the amount of time between a stimulus and a response.
That's what "increase the response time" means.
Herr's the code, I hope it helps someone solve my problem.
#include<Servo.h>
String data;
char d1;
String x;
int servoval;
Servo s1;
 pinMode (13, OUTPUT);
 pinMode (9, OUTPUT);
 s1.attach(9);        // make output 9 the servo channel
  d1 = data.charAt(0);
  switch (d1){       // select action based upon first character
    case 'A':       // first character is an A = turn on pin 13 led
    digitalWrite (13, HIGH);
    digitalWrite (9, HIGH);
    case 'a':       // first character is an A = turn off pin 13 led
    digitalWrite (13, LOW);
    digitalWrite (9, LOW);
    case 'S':       // first character is an S = set servo angle
    x = data.substring (1);
    servoval = x.toInt();
Personally I would not read the input into a String
See Serial input basics - updated for better alternatives
Can you make any suggestions for my program?
You never answered what the Serial timeout is set to
Don't use readString
Don't use Strings at all
If you look at the program, I don't have a serial time-out.
What do you suggest I use?
Oh yes you do !
The default is 1 second
Could that be your problem?
UKHeliBob
How and where do I change it?
