hey guys, i have problem with my project. i'm using 2 arduino uno that communication with UART. but the respon is very slow. can someone help me to fixed this problem?
here the code
//MASTER
#include <DHT.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h> //library untuk LCD dengan I2C
//deklarasi pin
#define water A2
#define pompa_air 7
#define fan 5
#define IR 11
#define Touch 10
#define buzzer 12
LiquidCrystal_I2C lcd(0x27, 16, 2);
DHT dht(4, DHT11); // deklarasi (pin, jenis DHT) pada DHT
Serial.begin(57600);
dht.begin();
lcd.init();
lcd.backlight();
pinMode(water, INPUT);
pinMode(IR, INPUT);
pinMode(buzzer, OUTPUT);
pinMode(pompa_air, OUTPUT);
pinMode(fan, OUTPUT);
pinMode(Touch, INPUT);
int sensor_touch = digitalRead(Touch); //membaca nilai sensor touch
int sensor_IR = digitalRead(IR); //membaca nilai sensor infrared
int sensor_water = analogRead(water); // Membaca nilai analog water sensor
float Level = map(sensor_water, 0, 1023, 0, 100); // Konversi nilai water levelsensor ke persentase
float t = dht.readTemperature(); // Membaca nilai suhu DHT
//lTampilan Pada LCD
lcd.setCursor(0, 0);
lcd.print("air:");
lcd.print(Level);
Serial.print("tinggi_Air :");
Serial.println(Level);
Serial.print("IR :");
Serial.println(sensor_IR);
Serial.print("Touch :");
Serial.println(sensor_touch);
Serial.print("suhu :");
Serial.println(t);
//KONDISI SENSOR WATER LEVEL
if (Level < 30) {
digitalWrite(pompa_air, HIGH);
digitalWrite(pompa_air, LOW);
//KONDISI SENSOR DHT
if (t > 32.00) {
digitalWrite(fan, LOW);
digitalWrite(fan, HIGH);
//KONDISI SENSOR TOUCH
if (sensor_touch == HIGH) {
Serial.write('A');
Serial.write('a');
//KONDISI SENSOR IR
if (sensor_IR == HIGH) {
Serial.write('B');
else{
Serial.write('b');
//SLAVE
#include <Servo.h> //LIBRARY UNTUK MOTOR SERVO
Servo myServo1; //DEKLARASI NAMA VARIABEL MOTOR SERVO1
Servo myServo2; //DEKLARASI NAMA VARIABEL MOTOR SERVO2
char message;
int pos;
#include <HX711_ADC.h>
#if defined(ESP8266) || defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout = 8; //mcu > HX711 dout pin
const int HX711_sck = 9; //mcu > HX711 sck pin
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 100;
#define buzzer 12
delay(10);
lcd.init();
lcd.backlight();
Serial.println("Starting...");
myServo1.attach(3); //DEKLARASI PIN MOTOR SERVO 1
myServo2.attach(4); //DEKLARASI PIN MOTOR SERVO 2
LoadCell.begin();
//LoadCell.setReverseOutput(); //uncomment to turn a negative output value to positive
float calibrationValue; // calibration value (see example file "Calibration.ino")
calibrationValue = 696.0; // uncomment this if you want to set the calibration value in the sketch
EEPROM.begin(512); // uncomment this if you use ESP8266/ESP32 and want to fetch the calibration value from eeprom
#endif
EEPROM.get(calVal_eepromAdress, calibrationValue); // uncomment this if you want to fetch the calibration value from eeprom
unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
LoadCell.start(stabilizingtime, _tare);
if (LoadCell.getTareTimeoutFlag()) {
Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
while (1)
LoadCell.setCalFactor(calibrationValue); // set calibration value (float)
Serial.println("Startup is complete");
static boolean newDataReady = 0;
const int serialPrintInterval = 1000; //increase value to slow down serial print activity
float i;
// check for new data/start next conversion:
if (LoadCell.update()) newDataReady = true;
// get smoothed value from the dataset:
if (newDataReady) {
if (millis() > t + serialPrintInterval) {
i = LoadCell.getData();
Serial.print("Load_cell output val: ");
Serial.println(i);
newDataReady = 0;
delay(20);
t = millis();
if (i < 30) {
myServo1.write(180);
myServo1.write(0);
if (Serial.available() >= 0) {
message = Serial.read();
Serial.println(message);
//MENJALANKAN INSTRUKSI ARDUINO MASTER UNTUK INPUT SENSOR TOUCH
if (message == 'A') {
myServo2.write(180);
} else if (message == 'a') {
myServo2.write(0);
//MENJALANKAN INSTRUKSI ARDUINO MASTER UNTUK INPUT SENSOR IR
if (message == 'B') {
digitalWrite(buzzer, LOW);
} else if (message == 'b') {
digitalWrite(buzzer, HIGH);
