Slow Serial Port connection with processing
can't understand this:
At least you have a building block.
delay() being removed was stupid.
indeed
Now I tried the opposite way with
int sensorPin = A0;
int ledPin = 13;
  pinMode (ledPin, OUTPUT);
  if (analogRead(sensorPin) > 500) {
    digitalWrite (ledPin, HIGH);
    Serial.println("1");
    digitalWrite (ledPin, LOW);
    Serial.println("0");
  delay(100);
on arduino
and
Serial myPort;  // Create object from Serial class
int val;      // Data received from the serial port
  size(200, 200);
  // I know that the first port in the serial list on my mac
  // is always my  FTDI adaptor, so I open Serial.list()[0].
  // On Windows machines, this generally opens COM1.
  // Open whatever port is the one you're using.
  String portName = Serial.list()[7];
  myPort = new Serial(this, portName, 9600);
void draw()
  if ( myPort.available() > 0) {  // If data is available,
    val = myPort.read();
    println(val);// read it and store it in val
  background(255);             // Set background to white
  if (val == 0) {              // If the serial value is 0,
    fill(0);                   // set fill to black
  else {                       // If the serial value is not 0,
    fill(204);                 // set fill to light gray
  rect(50, 50, 100, 100);
on processing
also on arduino side I tried different write to serial port methods:
serial.Write("int"); / serial.println(int); / serial.println("int");
and all gave me different results with the println on the processing side:
for example, the last one:
" 10 48 13 10 49 13 10 49 13 10 49 13 10 49 13 10 49 13 10 48 13 10 48 13 10 48 13 10 48 13 10 49 13 10 49 13 10 49 13 10 "
thanks again!
The 13 and 10 are the carriage return and line feed that the ln part of the name is responsible for adding.
The 48 and 49 ('0' and '1') look are like Serial.println(int); was used.
Thank you very much for your help: now i got things to work, it a great sequence of misunderstandings by me:
  1. the serial write example on processing is, like you very well detected, wrong;
  2. the physical pixel example on arduino ide works perfectly;
  3. The Graph example on Arduino ide has something wrong on the processing side.
in the end, through a sequence that I can't figure, it led me to wrong conclusions that without your help were impossible to detect...
Thanks a lot,
