Slow Strings :(
Hi, I've finally got some code working to accept mixed string commands from serial - they take the format A123 - where the letter indicates the destination of the numeric value at the end.
The code separates the letter and number and then assigns the value to one of 3 variables - depending on the letter.
However the code takes over 1000ms to run even though its short - I'm assuming that this is because im using strings....?
Id like it to be much faster (but not massively complicated - I'm not so hot on coding so far) - if anyone has any suggestions on how to speed it up I'd love to hear them.
Thanks in advance - Andrew
String incoming;    // Data received from the serial port
String letter;    //resulting letter from the string
String valString;   //value before its converted to an int
int incomingVal = 0;    //incoming value before its assigned to another variable
int valA;   //variables for motorspeed, pos etc
int valB;
int valC;
int startTime;    //for calc speed
  Serial.begin(9600); // Start serial communication at 9600 bps
  if (Serial.available()) {
    startTime = millis();
    incoming = Serial.readString();
    valString = incoming;   //copy incoming string so we can delete the number and letter seperately
    incoming.remove(1);   // remove everything but the first character to get the letter
    letter = incoming;
    valString.remove(0, 1);   //remove the first character from the string to get the number
    incomingVal = valString.toInt();    //convert string to int
    if (letter == "A") {      //assign the value to the correct variable
      Serial.println("Found A");
      valA = incomingVal;
    else if (letter == "B") {
      Serial.println("Found B");
      valB = incomingVal;
    else if (letter == "C") {
      Serial.println("Found C");
      valC = incomingVal;
    else {
      Serial.println("Incorrect Code!");
    Serial.println(millis() - startTime); //how long does the calculation take?
How long is the timeout for readString?
Your program will actually work, as well as be much faster, if you dump Strings and do this with character arrays (C-strings) instead.
See Serial Input Basics.
AWOL:
Cheers, just had a search around and added that to my program, works super fast now!
Feel a bit daft for not doing a proper search first! Sorry and thanks!
