SLOW
Anyone else annoyed by how slow the Arduino software is?
It is slow to boot up, it is slow to open or even load a sketch, it is slow to download the boot loader, and most annoying it that it takes in up words of 30 to 40 seconds to open the "Tools" menu.
It has been this way since version 18. Am I the only one seeing this? Back in version 10 and 11 things were very quick.
No you have something wrong, it opens instantly on both my Mac and PC.
Any clue as to what it could be? I have DL'd it twice and re-installed twice.
What system are you running on your PC?
It could be the java needs updating.
Windows Vista.
I have no clue how to check/update Java. It useually does that automaticaly.
http://www.ehow.com/how_2056389_download-java-windows-vista.html If it occurs with other applications too you might need to defrag your disks...
Thanks robtillaart, but it says I have the latest version and my disk is defraged once a week.
anyone else have any clues?
What does you taskmanager shows when you start Arduino?
Windows Vista.
Ah don't you just love Microsoft. It is probably going off to check something all the time. Have you tried running off line? Just disconnect your Ethernet cable or turn off your WiFi and see if that speeds it up.
Under processes or applications? Performance looks normal, CPU about 23% when starting up. Processes shows a Java icon with the new sketch name.
No differance.
I had a problem with Processing. It opened sketches very slow. It was because I had my workfolder/sketches on a mapped network drive. As soon as I stored my sketches localy everything was ok.
Does your computer have PDA / cellphone software installed?
What are your video settings?
Have you searched the forum for others that have had similar problems?
Do you have any bluetooth devices plugged in?
Well the dir is on Drive D: so I moved it all to Drive C: no differance.
nope.
Does this help?
System Information
Time of this report: 7/12/2009, 20:32:18 Machine name: Operating System: Windows Vista? Home Premium (6.0, Build 6001) Service Pack 1 (6001.vistasp1_gdr.090302-1506) Language: English (Regional Setting: English) System Manufacturer: ASUSTeK Computer Inc. System Model: G50V BIOS: Default System BIOS Processor: Intel(R) Core(TM)2 Duo CPU T9400 @ 2.53GHz (2 CPUs), ~2.5GHz Memory: 3070MB RAM Page File: 1736MB used, 4609MB available Windows Dir: C:\Windows DirectX Version: DirectX 10 DX Setup Parameters: Not found DxDiag Version: 6.00.6001.18000 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found. Sound Tab 1: No problems found. Sound Tab 2: No problems found. Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail) DirectDraw: 0/4 (retail) DirectInput: 0/5 (retail) DirectMusic: 0/5 (retail) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 9700M GT Manufacturer: NVIDIA Chip type: GeForce 9700M GT DAC type: Integrated RAMDAC Device Key: Enum\PCI\VEN_10DE&DEV_064A&SUBSYS_19A21043&REV_A1 Display Memory: 1779 MB Dedicated Memory: 499 MB Shared Memory: 1279 MB Current Mode: 1680 x 1050 (32 bit) (60Hz) Monitor: Generic PnP Monitor Driver Name: nvd3dum.dll,nvwgf2um.dll Driver Version: 7.15.0011.7580 (English) DDI Version: 10 Driver Attributes: Final Retail Driver Date/Size: 5/13/2008 21:43:00, 5865472 bytes WHQL Logo'd: Yes WHQL Date Stamp: Device Identifier: {D7B71E3E-450A-11CF-6F6E-A93901C2CA35} Vendor ID: 0x10DE Device ID: 0x064A SubSys ID: 0x19A21043 Revision ID: 0x00A1 Revision ID: 0x00A1 Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_A Deinterlace Caps:
Not yet. I have found that I seem to have unique problems. I thought sure that this was a common one and some one would quickly say "hay dummy, you have to turn ..... on" but to no evail.
No, but I do have a Bluetooth icon in the sys tray - I'll try turning it off. EDIT No differance
Thanks everyone for you help, keep the suggestions coming. The most annoying is the fact that I have to wait so long for the "Tool" drop down. the rest I can deal with.
Try 16 bit color depth.
No Dice.
I will try updating my vid driver.
Ok, the updated driver didn't do it.
I noticed that the Arduino Software list COM9 and COM12. I looked these up in the Device Manager and they are bluetooth stuff. Task Manager shows nothing about bluetooth device - So, how do I shut this down?
EDIT I disable the ports, but the tools drop down still takes forever to open. BUt COM9 and 12 no longer show in the serial list.
aggravating.
On mine, I've never seen words of 30 to 40 seconds. Which words were these?
If it's any consolation, I'm having the exact same problem with 0021. Mine only takes ~10sec to start-up and ~5sec for the tools menu but it's annoying none the less.
I've got Bluetooth stuff, but after disabling the service there was no change.
EDIT:Found the solution!
It was bluetooth and there's a really easy fix(Bottom of the first post, not the link at the top): http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1237179908
(Found Via: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1287002396 [Which is actually still on the first page of this forum right now.])
Hay thats great Azdle, but have you actually downloaded the rar file? All I get is a "Page not found" message.
Did the link work for you?
