Slowing Standard Servo in Code. Affect on Torque?
I've been trying to control the speed of a standard servo by incrementing its position degree by degree over time rather than a simple write to a given position.
  tnow = millis();
  elapsedTime = tnow - tlast;
  if (elapsedTime > motorPause) {   //check for how long motor has been stopped at a position
    int currentAngle = myservo.read();
    if (lastAngle == 0) {           //check position to know which direction to turn
      if (currentAngle == finalPos) { // if destination has been reached
        lastAngle = finalPos;         // reset checker variable
        tlast = millis();             // reset timer to next turn
      } else if (tnow % motorDelay == 0) {  // else, if destination has not been reached, every [motorDelay] milliseconds, enter this statement
        myservo.write(currentAngle + 1);    // increment position by 1
    } else if (lastAngle == finalPos) {
      if (currentAngle == 0) {
        lastAngle = 0;
        tlast = millis();
        myservo.write(currentAngle - 1);
I was just wondering if anyone knows of better ways to do this (I saw mention of a Variable Speed Servo Library that seemed to be doing something similar to what I coded, but don't know if there might be other benefits to using that or something else to what I wrote).
I'm also curious if anyone knows if slowing the servo motion this way negatively impacts the torque available.
Thanks!
I think the answer is "Not Much".. each servo has it's own error-motor-power characteristic.
The only difference in a large move may be the motor speed is higher as it decelerates near the set position. But Not Much.
Other opinions??
