hiii
iam using arduino uno and sm0038 ir receiver
it works good for the following code
#include <IRremote.h>
int receiver = 7;
IRrecv irrecv(receiver);
decode_results results;
irrecv.enableIRIn();
if (irrecv.decode(&results))
Serial.println(results.value);
irrecv.resume();
i want to make a ball and bat game on 16x16 led matrix display using 4 shift registers (74hc595)
i want to move the bat using ir remote(bat=>3 leds glowing).so to check the motion of the bat moving in a coloumn
i wrote the following code
#include <SPI.h>
int latchpin = 4;
int clockPin = 13;
int dataPin = 11;
int receiver = 7; //pin going to output pin of sm0038
unsigned long int bswitchvalue=0;
int batpos[3]={601,701,801};//601 represents the position of bat leds i.e 6th row and 1st coloumn
int batc,batr; //of the byte array l1[]
//i wrote in such a way that i can use those 6 and 1 values in bitset(),bitclear()
byte x;
byte l1[8]=
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B10000000,//here the three ones represent the bat position
B10000000,
B10000000
byte l2[8]={
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000
byte l3[8]={
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000
byte l4[8]={
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000,
B00000000
pinMode(latchpin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
SPI.setBitOrder(LSBFIRST);
SPI.begin();
if (irrecv.decode(&results)==true)
bswitchvalue =results.value;
irrecv.resume();
if(bswitchvalue>0)
switch(bswitchvalue)
case 3249147378:
batmotion1();
bswitchvalue=0;
case 3249163698:
batmotion2();
bswitchvalue=0;
disp();
void batmotion1() //function for corresponding button here bat moves up
if(batpos[0]>101)
batr=batpos[2]/100;
clearingbits(batr,1);
for(int i=0;i<3;i++)
batpos[i]=batpos[i]-100;
batr=batpos[0]/100;
settingbits(batr,1);
void batmotion2()
if(batpos[2]<1601)
batr=batpos[0]/100;
batpos[i]=batpos[i]+100;
batr=batpos[2]/100;
void settingbits(int R,int C)
if(R<9&&C<9)
R=R-1;
C=8-C;
bitSet(l1[R],C);
if(R<9&&C>8)
R=R-1;
C=16-C;
bitSet(l2[R],C);
if(R>8&&C<9)
R=R-9;
C=8-C;
bitSet(l3[R],C);
if(R>8&&C>8)
R=R-9;
C=16-C;
bitSet(l4[R],C);
void clearingbits(int R,int C)
if(R<9&&C<9)
R=R-1;
C=8-C;
bitClear(l1[R],C);
if(R<9&&C>8)
R=R-1;
C=16-C;
bitClear(l2[R],C);
if(R>8&&C<9)
R=R-9;
C=8-C;
bitClear(l3[R],C);
if(R>8&&C>8)
{ R=R-9;
C=16-C;
bitClear(l4[R],C);
void disp()
int i;
x=B10000000;
for(i=0;i<8;i++)
digitalWrite(latchpin,LOW);
SPI.transfer(B11111111);
SPI.transfer(~l1[i]);
SPI.transfer(B00000000);
SPI.transfer(x);
digitalWrite(latchpin,HIGH);
delayMicroseconds(500);
x=x>>1;
x=B10000000;
for(i=0;i<8;i++)
SPI.transfer(~l2[i]);
SPI.transfer(x);
x=x>>1;
x=B10000000;
for(i=0;i<8;i++)
SPI.transfer(~l3[i]);
SPI.transfer(x);
x=x>>1;
x=B10000000;
for(i=0;i<8;i++)
SPI.transfer(~l4[i]);
SPI.transfer(x);
x=x>>1;
when i upload the above code values other than the remote are found in serial monitor. ![]()
iam getting values even without pressing the buttons on remote.
please help me with the reason why this happening.
thank you
