I have an Arduino Mega (2560) board connected to a Sparkfun GPRS shield http://www.sparkfun.com/products/9607 and tried to request HTML pages.
I’m pretty sure the HTTP request is correct (I receive answers from the server) however, the page isn’t usually correctly received. I managed to observe three different kinds of behavior:
- page correctly received (normally pages with very small pieces of HTML code);
- page partially received (mainly pages with an huge HTML content eg, google page);
- pages which I get an “+CME ERROR 21” response eg, checkip.dyndns.org .
Since I’m trying to solve this problem for a few days, can anyone check the attached piece of code and give me any hints to receive correctly any web page?
Thanks in advance.
#define BAUD_GPRS 9600
#define BAUD_TERMINAL 115200
#define CMD_SIZE 50
#define SERIAL_DELAY 30
#define DELAY_LONG 40000
#define DELAY_SHORT 6500
#define DELAY_INIT 10000
#define DELAY_SEND 100
#define USER_AGENT "Mozilla/5.0"
#define SEND_STRING_SIZE 300
/* AT commands definition */
#define AT_GPRS_REBOOT "AT+CFUN=1,1" /* p.23 */
#define AT_GPRS_PDP_CONTEXT_PARAMS "AT+CGDCONT=1,\"IP\",\"internet\"" /* p.90 */
#define AT_GPRS_PDP_USER_PASS "AT+CGPCO=0,\"internet\",\"internet\", 1" /* p.95 */
#define AT_GPRS_PDP_ACTIVATION "AT+CGACT=1,1" /* p.96 */
/* included libraries */
#include <string.h>
char incoming_char = 0, cmd[CMD_SIZE], dump[CMD_SIZE];
char incoming_str[CMD_SIZE];
char ip[20];
char send_string[SEND_STRING_SIZE];
memset(send_string, '\0', SEND_STRING_SIZE);
Serial.begin(BAUD_TERMINAL);
Serial.println("Starting");
Serial1.begin(BAUD_GPRS);
delay(DELAY_INIT);
char_rx_from_GPRS(0, DELAY_SHORT);
create_PDP_context();
Serial.println("Ready to receive commands!");
int i=0;
if(Serial.available() >0)
delay(100);
while (Serial.available() != 0)
cmd[i] = Serial.read();
i++;
cmd[i] = '\0';
i = 0;
if (strcmp (cmd, "!gp") == 0)
Serial.println("Receiving a page.");
Serial.println("Configuring the remote host and port, to open a TCP connection");
Serial1.println("AT+SDATACONF=1,\"TCP\",\"checkip.dyndns.org\",80"); /* p.107*/
char_rx_from_GPRS(0,DELAY_SHORT);
Serial1.println("AT+SDATARXMD=1,1,1"); /* ASCII format p.111 */
Serial1.println("AT+TRT=12"); /* number of retries p.113 */
strcpy(send_string, "GET /");
strcat(send_string, " HTTP/1.1\r\n");
strcat(send_string, "HOST: ");
strcat(send_string, "checkip.dyndns.org\r\n");
strcat(send_string, "Connection: Keep-Alive\r\n");
strcat(send_string, "User-Agent: ");
strcat(send_string, USER_AGENT);
strcat(send_string, "\r\n");
Serial.println("Starting TCP/UDP connection...");
Serial.println(send_string);
Serial1.println("AT+SDATASTART=1,1"); /* enabling GPRS service p.108 */
char_rx_from_GPRS(0, 1000);
delay (1000);
char_rx_from_GPRS(0,100);
Serial1.print("AT+SDATATSEND=1,");
Serial1.println(strlen(send_string));
while(Serial1.available() > 0)
Serial.print( (char) Serial1.read() );
Serial.println("");
for(i=0; i < strlen(send_string); i++)
Serial1.print( (byte) send_string[i]);
Serial1.print(26, BYTE);
int j = 0;
do
Serial1.println("AT+SDATAREAD=1");
char_rx_from_GPRS(0, 10);
j++;
} while (j < 100);
char_rx_from_GPRS(1,100);
memset(cmd, '\0', CMD_SIZE);
Serial.println("Unknown command!");
void char_rx_from_GPRS(int mode, int delay_time)
memset(incoming_str, '\0', CMD_SIZE);
int i=0;
bool received = true;
while(true)
if(Serial1.available() > 0 && mode == 0) /* data to be received */
incoming_char = Serial1.read();
Serial.print(incoming_char);
received = true;
incoming_str[i] = incoming_char;
i++;
else if(Serial1.available() > 0 && mode == 1) /* data to be received */
Serial.print('\0');
received = true;
i++;
else if(!received)
return;
received = false;
delay(delay_time);
void create_PDP_context()
Serial.println("Creating PDP context...");
Serial1.println(AT_GPRS_PDP_CONTEXT_PARAMS);
Serial1.println(AT_GPRS_PDP_USER_PASS);
Serial1.println(AT_GPRS_PDP_ACTIVATION);
delay(DELAY_SHORT);
Serial.println("Done!");
