I had some free time today and decided to try to implement a 'handshake' between the program and my Arduino.
Its by no means complete, and it doesnt do much of anything, but I figure having the code up could help someone whos stuck doing serial, as I did run into a funny problem - the first try it would always time out, and the second time it would work fine. I added a line of code and commented it about this issue.
Main screen. Call button is disabled
until a port is selected (WIP!)
Notification that its found a port
(multiple port stuff is untested and
unimplemented as of this edit)
Information after the 'call'
is complete (takes about 500mS)
Project Link (Includes binary and source)
Arduino
if (Serial.available() > 0)
if (Serial.read() == 0x69)
// Model|Version|Serial
Serial.print("Arduino|v1.00|1337\n");
Serial.flush();
C#
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.IO.Ports;
using System.Linq;
using System.Text;
using System.Threading;
using System.Windows.Forms;
namespace Serial_Call
public partial class SerialApp : Form
bool multiplePorts = false;
public SerialApp()
InitializeComponent();
status.Text = "";
serialLabel.Text = "";
versionLabel.Text = "";
modelLabel.Text = "";
callButton.Enabled = false;
private void callButton_Click(object sender, EventArgs e)
serial.DtrEnable = true;
//serial.PortName = "COM3";
serial.ReadTimeout = 250;
serial.WriteTimeout = 250;
serial.Open();
if (!multiplePorts)
while (true)
try
serial.Write(new byte[] { 0x69 }, 0, 1);
string message = serial.ReadLine();
populateInfo(message);
break; // shouldnt get here unless read is successful
catch (TimeoutException) { } // dirty trick to get around the silly timeout exception on the first try
catch (Exception ex)
MessageBox.Show("Exception! Text: \n" + ex);
status.Text = "Failure!";
serial.Close();
private void populateInfo(string message)
string[] delimiter = new string[] { "|" };
string[] result = message.Split(delimiter, StringSplitOptions.None);
modelLabel.Text = result[0];
versionLabel.Text = result[1];
serialLabel.Text = result[2];
status.Text = "Success!";
private void searchButton_Click(object sender, EventArgs e)
string[] ports = SerialPort.GetPortNames();
if (ports.Length > 0)
foreach (string port in ports)
string devicesString = ports.Length + " device";
if (ports.Length == 0)
devicesString = devicesString + "s found!";
else if (ports.Length == 1)
devicesString = devicesString + " found!";
serial.PortName = port;
else if (ports.Length > 1)
multiplePorts = true;
MessageBox.Show(devicesString);
callButton.Enabled = true;
MessageBox.Show("No serial ports found!");
