Small concern found on LiquidCrystalCreateChar Reference code
Hello everyone,
I found a little something with the example code.
byte smiley[8] = {
  B00000,
  B10001,
  B00000,
  B00000,
  B10001,
  B01110,
  B00000,
When creating this character, the code only used 7 bytes, not 8. With beginners in mind, I would recommend adding the unneeded 8th byte "B00000" to give a clear template. Without all these bytes a beginner may not understand how to create a full character if the instructions were not completely read.
-Englishscone
Hi Englishscone. I think that is a very good suggestion. In addition to being potentially confusing, this also could lead to a confusing bug if the user made the smiley local (after all, why is it even global?). As a local variable, the uninitialized part of the array can have any values.
I notice that in the example sketch that comes with the library, the array is fully initialized (note they put the extra blank row at the top):
byte smiley[8] = {
  0b00000,
  0b00000,
  0b01010,
  0b00000,
  0b00000,
  0b10001,
  0b01110,
  0b00000
The people with access to edit the Arduino documentation aren't always able to keep up with all the posts on the forum, so there is a good chance they won't see your suggestion. The best way to bring it to their attention is to submit an issue to the bug tracker for the LiquidCrystal library:
Thanks!
pert:
LiquidCrystal/examples/CustomCharacter/CustomCharacter.ino at master · arduino-libraries/LiquidCrystal · GitHub
byte smiley[8] = {
0b00000,
  0b00000,
  0b01010,
  0b00000,
  0b00000,
  0b10001,
  0b01110,
  0b00000
https://github.com/arduino-libraries/LiquidCrystal/issues
Thanks!
Thank you so much! Wow that was my first karma, feels amazing haha.
Englishscone's issue report:
Thanks very much for doing that!
