Hi guys,
So I have an arduino Uno and a 6/9 volt small dc motor. I am trying to find a way to connect the dc motor to my arduino so I can control the speed. For example I would have a simple program where the motor runs at A speed for 3 seconds (A being the number I type in to set the speed). Any help or links to post for wiring? Thanks!
You cannot directly connect the motor to the Arduino. You need driver. This can be a transistor or preferably a logic level gate MOSFET. You then control the speed using PWM.
You must also put a reverse connected diode across the motor.
Weedpharma
I understand that it can't be directly attached. Do you know what specific type of transistor is needed?
Any one that will take the current of the stalled motor.
You can read all about how to control motors here:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
