I have been looking for a 3V arduino (or equivalent) that has a narrow footprint like the pro mini but with more pins (I am a bit short on pins to add some buttons) also the ftdi adapter is a pain to use into embedded projects
I found nothing in the arduino catalog, so I was considering using a maple mini, but it seems retired(not sure) and teensy do not seem to handle spi slave natively
The Micro has a few extra pins and on-chip USB so you get an extra hardware Serial.
The next step up is a Teensy. The 3.2 is just slightly bigger than a Mini and the Teensy 3.6 is much bigger. You get an onboard SD card slot and up to 6 hardware Serial with those.
have you thought of A parallel to serial shift register? the 74HC165 is 8 bits in - but it is 5 v - should be something for 3.3 v - takes only a few pins - I have used the serial to parallel 74HC595 - 24 outputs on I think 3 pins
They have a great micro board based on the 328PB (extra UART, more timers) for only $5. But if you need more pins and native usb the 32U4 model may be fit the bill:
MorganS:
I have micro's but I dont want to mess with ttl conversion for 3V
For the board, maybe a Sparkfun Pro Micro; has native USB and hence USB connector.
how can I figure the frequency of analogRead() on an arduino pro mini ? would it be fast enough ? I am also updating the lcd, there is the SPI interrupt for communicating with a teensy, and also a software serial to communicate with an hc05...that seems a lot
No, that's not a lot. Reading the buttons 20 times per second is enough to appear instant to a person pushing buttons. With that load you will be more like 200-1000 loops per second.
Normal analogRead takes approx. 100 microseconds. If that's too slow, you can look how analogRead is implemented.
It sets up the read and starts the conversion and next waits till a flag is set indicating that the reading is finished. You can easily split that in a function (e.g. analogStart) to setup the read and start the conversion and a non-blocking function (e.g. analogFinish) to poll the flag, return e.g. -1 if not completed and read the relevant registers and return the value if completed.
phil123456:
I'll have a look at this one...(I also thought about using an adruino micro with a voltage divider for ttl compatibility)
but how do I figure the implementation of analogRead on arduino pro micro ? I guess it changes from one to another
thanks
Never worked with a Pro Micro. You can install the board by following the instructions on the Sparkfun website; this might not be strictly necessary, I'm not sure.
How many more pins do you need than the pro mini has, and what do you need them for? It's often easier to crunch up the resources needed by your program, than it is to use new hardware.
