small helppppppp!!!!!!! required
i have reached to the conclusion that the whole problem is based on the incorrect format of the varible
but cannot change variables format
i have attached a photo
when i try to print an element of array it prints something useless
but when i try to print the orignal value (results.value)
it works fine
pls helpppppppp!!!
code
int t =0;
int a=0;
int b=0;
byte gone[50];
#include <IRremote.h>
int RECV_PIN = 10;
int i = 0;
int m = 0;
pinMode(11 ,OUTPUT);
pinMode(10 ,INPUT);
pinMode(13 ,OUTPUT);
pinMode(12 ,OUTPUT);
pinMode(3 ,INPUT);
pinMode(2 ,INPUT);
a = digitalRead(2);
b = digitalRead(3);
if( a == HIGH || ( i != 0 && i != 51 )){
IRsend irsend;
Serial.println(“transmit”);
Serial.println(i);
irsend.sendNEC(gone[ i ], 11);
Serial.println(gone[ i ]);
Serial.println(" ");
delay(40);
i ++;
}else{i = 0;
if( b == HIGH ){
digitalWrite(12,HIGH);
IRrecv irrecv(RECV_PIN);
irrecv.enableIRIn();
decode_results results;
delay(100);
if (irrecv.decode(&results)) {
Serial.println(“recieved”);
gone[m] = (results.value , HEX);
Serial.println(gone[m]);
Serial.println(c);
Serial.println(results.value, HEX);
digitalWrite(13,HIGH);
digitalWrite(13,LOW);
irrecv.resume();
m ++;
universal_remote.ino (941 Bytes)
This looks rather odd:
gone[m] = (results.value , HEX ) ;
I’m sure it is not doing what it looks like you expect it to.
results.value appears also to be too big to fit into a single byte.
Thx for you help
